Best Turbo Piston size for a good set up
1. AEBS Sleeved 84MM bore, B18c Block
2. Eagle Rods
3. CP Pistons (....?...)
4. Turbonetcs T3/T4
5. B18c JDM Head
I want my block to be set.
What size of pistons would work the best with this set up. my goal is to max my turbo at 450whp. Later, go to a bigger turbo GT35r and add all the head work then. springs/retainers/valves/port and pollish....
With my stock head i will only be reving up to 8500K...
What do you guys or gals suggest.
2. Eagle Rods
4. Turbonetcs T3/T4
5. B18c JDM Head
84mm Pistons, the same as your bore. You really should get the pistons then have your block bored to match... Or do you mean what type of dome/dish pistons should you get for a certain compression ratio?
