EG Civic No Fuel or Spark
Old Jul 14, 2009 | 09:51 PM
jOnW89's Avatar
Default EG Civic No Fuel or Spark
I have a 1994 Civic hatch VX with gsr car ran fine went to go start next morning and no fuel or spark -_- I am stumped.
What I have tried:
New main relay
New Engine Harness
More ground wires
Different ECU
Thermostat ground I checked and is fine
Old Jul 14, 2009 | 09:54 PM
96DelSol's Avatar
Default Re: EG Civic No Fuel or Spark
hmmm does the starter crank at all?
Old Jul 15, 2009 | 05:34 AM
Former User's Avatar
Is fuse 31 (hood), 24 (dash), or 18 (dash) blown?
Old Jul 15, 2009 | 07:04 AM
zerovandez's Avatar
^^Yeah, check your fuses.
Old Jul 15, 2009 | 07:11 AM
ej1bmx's Avatar
Have you checked all of the ground wires? My tranny ground got messed up and the same issue!
Old Jul 15, 2009 | 07:51 AM
instrument's Avatar
yeah what exactly happens
got power if you turn the key?
Old Jul 15, 2009 | 08:25 AM
jOnW89's Avatar
Yes, my starter cranks I just get no spark from the dizzy and my fuel pump wont prime. All my grounds are fine. My fuses are also fine.
Old Jul 15, 2009 | 09:17 AM
Give more details.
Did you check the three fuses with a multimeter?
Does the CEL remain ON steady with and without the service connector jumped?
With the key in ON(II), does battery voltage get to both the distributor and the main relay?
Old Jul 15, 2009 | 01:21 PM
jOnW89's Avatar
Originally Posted by RonJ@HT
Give more details.
I am not throwing a code that would stop it from getting spark or fuel. No I didn't chec the fuses with a multimeter.
Old Jul 15, 2009 | 01:24 PM
swapshop's Avatar
have u tried a dif distribitor sounds like a gay ground problem i ran into that crap beofre does nothin but **** u off
Old Jul 15, 2009 | 02:07 PM
Do the distributor and main relay get battery power? If not, go back and check the ground wires again.
Bryantcuhz
Jul 27, 2014 05:04 PM
slobalt05
28
Dec 29, 2010 06:45 AM
jeephonda
Aug 23, 2010 11:08 AM
mangodade
Mar 18, 2010 05:30 PM
hybridmath
30
Jul 20, 2008 03:38 PM
