93 civic ABS and BAT light after battery charge?
Old Jul 14, 2009 | 05:46 PM
tlarimer's Avatar
Icon2 93 civic ABS and BAT light after battery charge?
I have a 93 civic 4dr EX, battery was dead, but when my brother, trying to help out, put the charger on the battery, he forgot to switch it from deep cycle/marine to regular charge. Now it starts, but the ABS and BAT light are on. What do I need to be looking at? I checked all the fuses and none are blown, so what am I missing? Thanks guys for the help.
Tim
Old Jul 14, 2009 | 06:14 PM
Former User's Avatar
Default Re: 93 civic ABS and BAT light after battery charge?
Focus only on the battery/charge light. When this is fixed, clear the ABS code and only address if the ABS light returns, which it likely won't.
My guess would be that the battery was damaged by improper charging.
Old Jul 15, 2009 | 11:37 AM
tlarimer's Avatar
I swapped out the battery with a known good one from my 92 EG6, same thing happened. The fan barely blows on #4, the clock is dim and the power windows and moonroof are slow. I am leaning toward the ALT, unless I am missing a relay or fuse somewhere? Let me know what you guys think.
Thanks, Tim
Old Jul 15, 2009 | 11:48 AM
Are the battery connectors/posts and ground wire clean and tight? With the engine idling, what voltage do you measure across the two battery connectors?
Old Jul 15, 2009 | 05:24 PM
tlarimer's Avatar
New battery and ALT, problem solved.
shandar
Jul 11, 2017 08:59 AM
esanchez
Nov 21, 2010 12:10 AM
95TEG
Sep 17, 2006 09:14 PM
kupras
Sep 7, 2005 02:05 PM
Jon7
Sep 4, 2001 09:01 AM
