what bearings to use
Old Jul 14, 2009 | 12:30 PM
divads's Avatar
Default what bearings to use
i have a question for those who has done the ls crank and rods into the gsr block what bearings are you guys using ls ones or gsr's
i've searched and have not found a straight answer
as i am doing this and need to know what bearings to get
Old Jul 14, 2009 | 12:33 PM
b19coupe's Avatar
Default Re: what bearings to use
The main bearings are the same. Use LS rod bearings.
Old Jul 14, 2009 | 12:54 PM
divads's Avatar
thank you very much
red_crx's Avatar
X2, or you can always have your ls rods retanged to use gsr rod bearings.
Old Jul 14, 2009 | 01:20 PM
1200 Hobos's Avatar
^ I was wondering if you could do that with LS rods, thanks. According to Omnimans 200whp b16 build that dyno'd 206 whp; it's better to use the GSR rod bearings. They're designed to handle high rpm better than LS bearings which made sense to me. Although I wouldn't exactly take my word over b19coupe, I've never built a motor.
Old Jul 14, 2009 | 01:25 PM
092eg6's Avatar
I would only use GSR rod bearings if im trying to find the very last Horse power that the engine can make, other than that LS rod bearings are fine.
Old Jul 14, 2009 | 01:30 PM
morgan@synapse motorsport's Avatar
Aftermarket LS bearings, as the OE are not too durable. If you insist on OE then get B16a bearings
m88ulrich
Engine Machining & Assembly
Mar 30, 2018 08:39 PM
Hellahflush
Jan 28, 2015 07:20 AM
Rheg6
Jan 9, 2012 06:36 PM
Spence
32
Sep 29, 2005 03:32 PM
lsvtec101
Jan 14, 2004 05:19 PM
