1994 Accord LX Fuel Pump Relay
Old Jul 14, 2009 | 05:10 AM
Mackln308's Avatar
Default 1994 Accord LX Fuel Pump Relay
I know the fuel pump relay in the accord is not functioning properly as I have bypassed the relay and the pump works fine but does not start when it is not bypassed. However, I am having a hard time finding the fuel pump relay. The research I have done suggests that it is under the dash near the steering column..... Does anyone have any diagrams or better directions to find this fuel pump relay?
Thanks,
Nick
Old Jul 14, 2009 | 06:11 AM
billyrusa's Avatar
Default Re: 1994 Accord LX Fuel Pump Relay
It is located underdash and between the steering column and the heater unit (close to steering column). There are 7 wires connected to the bottom the the relay. The colors of the 7 wires are: GRN/BLK, BLU/RED, BLK, WHT/GRN, YEL/BLK, RED/WHT, and BLK/YEL.
Old Jul 20, 2009 | 08:35 AM
Mackln308's Avatar
the only relay i can find is a mitsuba rz 0088 and it isn't named fuel pump relay.... just the mail relay something or other. wires are similar in color; is this the relay?
Old Jul 20, 2009 | 09:14 AM
billyrusa's Avatar
The Main Relay is the fuel pump relay.
Old Jul 20, 2009 | 03:31 PM
bobwallace's Avatar
I had to remove the cruise control box to get to mine when it stopped working.
Old Jul 11, 2011 | 05:34 AM
demonic1985's Avatar
Which are the cables for the relay
Old Aug 6, 2012 | 07:47 AM
Gscheideger's Avatar
I can not find a good wiring print for the fuel pump relay for a 1994 honda accord ex. The one I found does not match up with the car. I Ohmed out the wire to the pump and it is #7 but the print says it should be #4 which my relay does not have a #4 pin.
Old Aug 8, 2012 | 07:42 AM
ron4me's Avatar
where is the fule pump located haveing a problem with my pump also I have a relay to put in just want to know just in case it is the pump
Old Aug 21, 2015 | 08:49 AM
Jordan Bruno's Avatar
How did you bypass the relationship and get the pump to work.
slowEGles
May 13, 2013 06:16 PM
thiendegigolo
Jul 23, 2010 05:38 AM
JaHnAbOi
Oct 4, 2004 10:39 PM
speedaccordinly24
Apr 7, 2003 09:23 PM
RenoRacing
Sep 8, 2002 09:41 PM
