FS: Built EG Civic, Clean chassis, Spare ITR bottom end, ITR Trans, Sparco Seat, Defi
Old Jul 13, 2009 | 09:38 PM
snowman4us's Avatar
Default FS: Built EG Civic, Clean chassis, Spare ITR bottom end, ITR Trans, Sparco Seat, Defi
Alright, up for sale is my 1994 Civic VX.
Price: 7K OBO.
I bought the car with a full intention of building a wheel to wheel race car, and some of the build was put together around that. I got the car about 6 months ago, and put on about 500miles on it max, and most of it is from the first 2 weeks of having it.
Mods:
Engine:
B18B Short Block
GSR Head (rebuilt with all OEM parts 100 miles ago)
Skunk 2 Intake Manifold (100 miles on it)
Skunk 2 Springs and Ti retainers
Gates Racing Timing belt (50 miles on it)
Moroso Road Racing Oil Pan
External Oil Cooler with oil filter relocation kit
Cap and Rotor (oem 200 miles)
Mishimoto Radiator
Passanger side axle (100 miles)
Greddy Catch Can
AEM fuel rail and FPR along with gauge
Inovative motor mounts
DC 4-1 header
Custom exhaust with what looks like Apex-I noir muffler (quiet)
Still catted (should pass emissions)
GoldenEagle LS-Vtec kit (50 miles)
GSR Cams
P28 chipped ECU
ARP Head studs (200 Miles)
ARP Rod bolts (50 miles)
BuddyClub Water Remp addapter (50 miles)
Trans:
ITR Tranny with LSD, hydro
ACT Pro-lite fly wheel
Exedy Clutch (has about 90% life left)
Suspension:
Tein Super Street Coilovers (great condition, no rust or problems)
Muger rear trailing arm Pivot Bushing
Special Projects Spherical Front lower control arms
GSR Front and rear Hubs
OEM front lower ball joints (100 miles)
Skunk2 Front Upper Control arms
Brakes:
GSR Front and rear brake conversion
40/40 per. valve
ATE Super Blue Brake Fluid
Wheels:
Drag RPF-1 Look alikes 15X6.5
Brigestone RE-01R's 195/50-15 (100 miles)
Moteki Lug nuts
Interior:
Completley stripped other then the front door skins and Dash (no heater or AC).
Sparco Pro2000 (1.5 years old, still good for 3.5 years of FIA certificaton.)
Sparco Side Mounts
Sparco 6 point harness (same age as the seat)
Sparco/Prodrive Steering Wheel (100 miles)
Momo Hub
Greddy Water Temp Gauge
Defi Oil temp Gauge (100 miles)
Defi Oil Pressure Gauge (100 miles)
AEM Eugo A/F wide Band (20 miles)
GTSpec oil sandwich addapter Plate
Exterior:
The car does not have a single rust spot, fade spot in the paint, bondo, dinged up panels. I was very **** about getting a chassis to start from that was in the best condition. And this is one of the cleanes EG chassis I have EVER seen that has not been fully restored.
Dark Green Paint
Carbon Duck Bill
JDM Head lights
Spare Parts:
Was planning on building up a high compression race motor.
JE 12.5:1 Pistons (brand new but one got a ding so it needs to be replaced) 81.5MM
GSR Cranks, just got inspected, cleaned, and micro pollished by ProMachine
ITR oil Pump (new)
GSR Water pump (new)
Clevite race bearings, main, rod, thrust (new)
B18C5 Block, 81.5mm
HPS Front Pads (new)
Skunk2 Front upper controll arms
OEM front and rear brakes
OEM Rear struts
GSR leather Front and rear seats
2 way alarm system with romote
Only thing the car would need is front and rear rotors, pads, and stainless steel lines, and it would be ready for road racing, or drive it around as it is for fun or build as a drag car. As you can see there is almost everything there to build the motor other then gaskets. With a good set of cams the motor will be good for a bit over 200WHP and 9,500 RPM. Put in a SCCA legal cage, and you are ready for Honda challange, the car is only 300 dollars max away other then a cage to be ready for any sort of road racing. Or Just take it out as it is, and dominate AutoX or time attack
you can pm or email me at snowman_4_us at hotmail dot com
Thanks
Way the car looked like when I picked it up
Sorry it was dark outside, so i did the best I could.
First Pic was right before i put in th oil cooler core. The core now sits in the driver side lower air dam behind the bumper.
The block is honed, and is the spare one that comes with it.
Some pics where taken before the GSR seats got take out.
As you can see the tires are brand new, and have plenty of meat still on them. And they are stick too
The wiring harness as you can see at one point was completley out of the car, as i was able to clean it up and take out the un-needed ones.
Flywheel is a ACT ProLight unit. 8.9lbs IIRC.
Old Jul 16, 2009 | 05:56 PM
snowman4us's Avatar
Default Re: FS: Built EG Civic, Clean chassis, Spare ITR bottom end, ITR Trans, Sparco Seat,
bump
Old Jul 16, 2009 | 06:01 PM
BoostKiller's Avatar
How much for the itr block
Old Jul 16, 2009 | 09:13 PM
jerdear's Avatar
Ya, what he said. How much for the ITR block?
Old Jul 16, 2009 | 11:10 PM
-ThePhantom-'s Avatar
Yea what they said ha
Old Jul 16, 2009 | 11:17 PM
Eran's Avatar
HT White Ops
Utah is not in the Northwest.
Old Jul 19, 2009 | 08:09 AM
snowman4us's Avatar
Portland and Seatle and closer then Kansas...but the almighty Honda Tech Mods fail to use google earth.
And no part outs.
Old Oct 2, 2009 | 11:10 AM
mrlegoman's Avatar
Bump for an all around good deal. No rust EG's are hard to find.
Old Oct 2, 2009 | 11:21 AM
Fantastic420's Avatar
F***** sick! Nice hatch, good luck with the sale.
swissromance
May 30, 2012 05:58 AM
h22bb1
Aug 16, 2011 05:58 AM
Juggernaut 2
Sep 6, 2005 02:21 PM
