Turbo R Dynoed and tuned......finally!
Old Aug 22, 2002 | 05:09 PM
Type-ARR's Avatar
Default Turbo R Dynoed and tuned......finally!
Well after having my little problem with the AEM EMS I switched to Hondata 2b and got the car to the dyno today.
The car made 240.1 whp and 160.7 ft-lbs @ 8 psi
the compression was lowered to about 9.4~9.5:1
Also I think the car would have made a bit more power but it was over 100 degrees in the dyno room. I think too that my 60mm apexi N1 exhaust was holding me back some. We did pick up about 25 whp just by regaping the plugs and adjusting the cam gears a bit. Overall Im pretty happy with the performance of the car and the Hondata system.
Hondata =
Old Aug 22, 2002 | 05:14 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Turbo R Dynoed and tuned......finally! (TurboR481)
I think i can take you
Rguy, who has two cases of beer right here for that EMS
Old Aug 22, 2002 | 05:33 PM
nekkedR's Avatar
Default Re: Turbo R Dynoed and tuned......finally! (Rguy)
cool deal, i just got my turbo R on the road last weekend,im also running the hondata 2b,but stock compression, i have yet to take it to the dyno for tuning.so im just creeping around at 4psi
Old Aug 22, 2002 | 05:47 PM
AllMotorITR's Avatar
New User
Default Re: Turbo R Dynoed and tuned......finally! (nekkedR)
only 240whp @ 8psi!!!!! What kit are you running again? Rev Hard Stage 2?
Old Aug 22, 2002 | 05:49 PM
Mike95lude's Avatar
that torque is horrible...
Old Aug 22, 2002 | 05:53 PM
Type-Rare#1248's Avatar
Default Re: Turbo R Dynoed and tuned......finally! (Mike95lude)
afterall, that is a turbocharged 1.8L not a turbocharged 5.0L V8
Old Aug 22, 2002 | 06:26 PM
TurboR1391's Avatar
Yea, do you think it is a 2.2 liter H22
Old Aug 22, 2002 | 07:29 PM
SurferX's Avatar
Peak numbers are for dyno hogs, it's the curve that counts. Let's see the chart!
Old Aug 22, 2002 | 07:46 PM
Turbo R's Avatar
josh.....nice numbers....HONDATA is the ****!!! you gonna take it to the track this season?
Old Aug 22, 2002 | 08:06 PM
Type-ARR's Avatar
Default Re: Turbo R Dynoed and tuned......finally! (NA ITR)
Yes Hondata is the ****....., well bobby I have to get my stage 3 clutch in before I run it but it might be ready by battle if not I will run when I get back from school in DEC.
I just want to also thank Terry and Shad for getting my **** tuned, they are awsome,......bobby knows who they are.
Old Aug 22, 2002 | 08:37 PM
New User
I think you need to tune a little more!!!
Old Aug 22, 2002 | 08:55 PM
1.8TypeR's Avatar
how easy is it to tune with the hondata??? im debating on getting either the hondata or aem.
right now i make 241whp/169.9lb/tq @6.8psi with rc 310's and vafc. i also need to switch out my 60mm N1 exhaust too.
stock internals/compression.
[Modified by 1.8TypeR, 9:56 PM 8/22/2002]
Old Aug 22, 2002 | 10:31 PM
TurboITR's Avatar
Default Re: Turbo R Dynoed and tuned......finally! (1.8TypeR)
now its time to up the boost
sohctodohc
Nov 29, 2004 12:03 PM
vtecb20coupe
Oct 22, 2004 04:23 PM
18gLUDE
Jan 29, 2004 03:26 PM
