HONDA VETS HELP ME PLEASE!?!??!?!?!
ok so i have an 88 ef with a 95 d16zc sohc motor in it, the ecu is a chipped p28 obd1, the motor has the obd1 map sensor on it HOWEVER, i changed the map sensor that bolts on the top of the throttle body, now the old map sensor on the firewall ( the stock ef one) i pulled the plug out of the bottom and pluged it into the obd1 map sensor, now wat do i need to do with that top plug, do i need to get a second new sensor for the top plug, do i unplug it, i left it hooked up to the sensor that has the vac lines that run into the cannister and the back of the intake manifold.
SO NOW TO MY PROBLEM........the car is idling fine, but when i give it a little bit of gas it starts to stutter, i keep giving it a lil and lil more gas and it continues to stutter until it reaches a point where it starts revvin hella high and the studder stops but theres no smooth transistion its either revin love around 2000 rpms and stuttering and then i give it a lil more gas and it switches and runs like 5000 an does stutter, i have changed most of my parts, map sensor to obd1, ive changed the main relay, im at a loss for wat is wrong with the car, any insight would be greatly appreciated? give me some tips and ill tell you if ive tried it fixed it or changed it, ive been at this for almost 2 months now and this car is way to simple to be this big a pain in the ***. PLEASE PLEASE PLEASE PLEASE HELP IM LOSING MY MIND WITH THIS PIECE
Cool Cool Island Breezes. BOY-EE
So you're saying that the car was stuttering and giving you issues before you changed out the map?
Was it newly swapped and you always had the issue...or did the problem just start happening out of nowhere?
the motor is freshly swapped, the timing is perfect i checked that and double checked that, the problem started from the very beginning, i had the obd1 computer on there and had the stock map sensor for the 88 ef hooked up and thats when it was doing it, so then i releazied i had to changed the map sensor, so i took out the bottom plug and attached it to my new map sensor at the top of the intake mani and then the second plug the top one on the old map sensor is still plugged in, so i dont know if there is a second obd1 sensor i need for that? so ya after i put the new obd1 map sensor on and plugged it in its still doing the same thing i figured that my problem was the obd0 map sensor with the obd1 comp
Just leave the top connector for the purge control solenoid plugged in. I don't see this doing any harm as it is just part of the evaporative control system.
Regarding the rough running, in what condition are the plugs, wires, cap, and rotor? Is the CEL ON?
the plugs wires are new the dizzy is off hondatech, but its the second one ive tried on the car with the same results and i did change the ignitor in the dizzy.
Also make sure that the plug wires and injector plugs are in the correct firing order and that no sensor connectors are swapped.
someone on ef-honda.com told me that i had to switch osme wires at the tps? anyone know anything about that im using the obd1 tps so idk why i would have to switch wires
i honestly dont understand wat it could be, as far as i can tell everything is hooked up all the sensors are good, OH there is no o2 sensor hooked up but i doubt it cause wat im experiencing
Should be like connector on the right. Also check whether the CEL works. At the very least, the CEL should be ON for the missing O2 sensor. But pull the codes as others may be stored in the ECU.
srt4pilot
11
Jul 14, 2009 10:10 AM
BoRiCuA
Jun 30, 2004 06:06 AM
