JDM B20A w/ GSR head
Old Jul 13, 2009 | 06:36 PM
devildogd's Avatar
New User
Default JDM B20A w/ GSR head
I need input that I'm swapping my D16 out and wanting to do something different. I chosed to do a B20A from a Prelude w GSR header. Is this going to a be a difficult project and something stupid?
Old Jul 13, 2009 | 06:42 PM
BiG ChOr!Zo's Avatar
Default Re: JDM B20A w/ GSR head
About The B20A :
The Honda B20A engine shares little in common with the rest of the B-series of engines. It was first seen in Japan and similar markets in 1985. This engine came in the 2nd generation (1985-1987) Prelude and 3rd generation (1985-1989) Accords. With dual overhead cams, 2 liters of displacement, Programmed Fuel Injection (PGM-FI), the engine was capable of outputting up to 160hp and 140lb-ft of torque.
This engine is not to be confused with the B20A3/5 found in the 1988 to 1991 BA5 Preludes or the B20B/Z That came in the Orthia or CR-V. It was not available in the North America, and they are extremely hard to come by there. Most engine importers won't even know the difference, and will probably confuse it for the B20A from the 3rd gen Prelude.
A 1.8 liter varient of the B20A was also made, called the B18A, Came in the CA2 honda accord/vigor from japan, It was a 130PS engine that ran on twin sidedraught carbs, The head is totally different to the B20A head cause of the square intake ports for the carb manifold. The block is simply a destroked B20A, The heads swap over so a B18A EFI conversion is possible. Everything else from the B20A bolts right on.
Old Jul 13, 2009 | 07:32 PM
devildogd's Avatar
New User
Thanks for the info. Let see if my mechanic and I can make it happen
8dxhatchy8's Avatar
wont work....
Old Jul 14, 2009 | 04:57 AM
devildogd's Avatar
New User
why would you say that?
Old Jul 14, 2009 | 05:18 AM
jdmwannabee's Avatar
Originally Posted by 8dxhatchy8
wont work....
because
Originally Posted by BiG ChOr!Zo
About The B20A :
/thread
Old Jul 14, 2009 | 03:33 PM
8dxhatchy8's Avatar
if ur gonna use a B20 make sure its a B20B/Z
Old Jul 14, 2009 | 03:46 PM
D16SiHatch's Avatar
what he said ^
you cannot install any other b-series head onto a b20a block, besides the one it came with stock.
Old Jul 14, 2009 | 05:10 PM
ALLxMOTOR EG's Avatar
Vietnamese!
wont work....
Old Jul 14, 2009 | 09:38 PM
Eli2's Avatar
Yea this was covered in another thread as well. The B20A is not compatible with any of the other B-series motor parts.
Eli
Old Jul 15, 2009 | 05:29 PM
devildogd's Avatar
New User
thanks for the heads up
BONNARSKI
Dec 19, 2011 09:43 PM
jmcclell
Nov 8, 2005 06:20 AM
HksHaitian
May 2, 2005 07:00 PM
