b20vtec swap help
Old Jul 13, 2009 | 12:13 PM
wbaldwin_86's Avatar
Default b20vtec swap help
hello, i have just finished my b20vtec swap in my 1997 gsr. the car starts and idles great until i touch the gas then let off the gas. when i let off the gas the rpms will drop very low and die. when the motor dies i can hear the iacv making a humming/buzzing noise. i know that it is the iacv because the noise goes away when i unplug it.
here is a list of things that i have done to try and fix this.
-clean the iacv
-swapped the iacv with three different valves
-swapped the ecu
-measured the voltage of the iacv plug
-i have tried to set the rpm with the screw on the throttle body(when the iacv is unplugged the car will die)
-checked the tps
-changed map sensors
so any and all help will be appreciated very much
thanks a lot bill
Old Jul 13, 2009 | 12:16 PM
dlaub25's Avatar
Default Re: b20vtec swap help
-clean the iacv
-swapped the ecu
-checked the tps
thanks a lot bill
What kind of engine management are you using?
Old Jul 13, 2009 | 12:32 PM
right now i am running a obd1 p72
Old Jul 13, 2009 | 12:34 PM
kyden's Avatar
do you have evap hooked up?
Old Jul 13, 2009 | 12:43 PM
no i don't.
Old Jul 13, 2009 | 02:32 PM
BIG T's Avatar
evap shouldn't matter since he is running an OBD1 ecu
Old Jul 13, 2009 | 05:10 PM
dlaub25's Avatar
Is it a stock ecu or does it have a map on it.
Old Jul 13, 2009 | 05:25 PM
jkeno112's Avatar
messed with the wiring by chance?? obdII to Obd I.. recheck or change out the tps and/or map. what throttle body are you using??
Old Jul 13, 2009 | 05:49 PM
the ecu is a stock obd1 ecu
i bought a jumper harness, i am going to check that out.
Old Jul 13, 2009 | 06:32 PM
092eg6's Avatar
thats your problem! Im 100% positive. Get that ECU chipped and order a base map for your motor! or just get it tuned!
Old Jul 13, 2009 | 07:48 PM
well i figured it out. it was the pcv valve
ERIC1
17
Jan 19, 2010 08:34 AM
BIG T
Jul 14, 2009 04:35 PM
BIG T
Engine Management and Tuning
Jul 13, 2009 06:36 PM
vi3tromanc3r
Aug 30, 2008 12:10 AM
FLIPboi
Aug 29, 2002 07:16 PM
