won't start :/
ok i need help diagnosing a problem on my 2007 si coupe
when i turn my key to the accessory or on position all of my dash lights up and then off and back on and off repeatedly,this includes everything except rpm. sometimes my rpm will jump a little also maybe to say 1000 or 1200 and then it goes right back to 0 but not always.
there car is not turning over when i press the clutch in and continue to try to start is so it leads me to believe...
electrical ?
maybe ignition?
thanks for everyones help in advance.
electrical ?
maybe ignition?
i have an intake leak about 1.5 or 2 inches before the Intake manifold and thats it. was gonna order takeda soon and bolt it on so i wouldn't hear it anymore lol.
thats the only thing really wrong .
no tested and its fine. there was alot of corrosion on the positive though. cleaned it with coke and put some junk on it that suppossed to prevent corrosion.
This is what I was going to suggest. I had the same thing happen to me. One day everything was fine, then the next morning I had a similar issue. I called my mechanic and he said change the battery. I did and everything was been fine. Seems when the factory battery goes, it goes all at once.
thecivicsi
May 8, 2012 07:26 PM
91sicrxer
17
Jun 15, 2005 08:10 AM
