Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
crv immobiliser
Old Jul 13, 2009 | 10:33 AM
beano99's Avatar
New User
Default crv immobiliser
hi all im new to this site but a regular to turbod16
need help with a immobiliser on a 1998 auto crv b20
ecu code 37820-p3f-g51
engine turns over ive got spark but no fuel comin though injectors
tested them and they work fuel pumps workin.
can i bypass immobiliser or can i just change the black box and key
r they linked to the ecu?
please help
Old Jul 15, 2009 | 09:59 AM
NDNV's Avatar
Default Re: crv immobiliser
Your ignition switch has a recall on it. I would check for a faulty ignition switch.
Old Jul 15, 2009 | 04:38 PM
19slocivic97's Avatar
no immobilzer on 98 crv!
Old Jul 15, 2009 | 09:29 PM
beano99's Avatar
New User
wats a recall
it does ave a immobiliser on it its a megamos box under the steering wheel and barral as a pik up on it
Old Jul 16, 2009 | 09:23 AM
i have a 99 ex and it doesnt have immobilzer, and recall from the factory
do you have a green light in the cluster that looks like a key? if not you dont have HONDA IMMOBILIZER, you may have an aftermarket unit, i just cecked to be sure immobilzer wasnt on any crv untill 2002, you said you have a 98
Old Jul 16, 2009 | 10:31 AM
extream_86's Avatar
from a 5 year honda tech. no immobi on 98 crv
Old Jul 16, 2009 | 05:57 PM
you got me by a year, maybe two honda techs will convince him...hahaha
Old Jul 16, 2009 | 07:55 PM
redej878's Avatar
Another tech here, no Immobi.
Old Jul 17, 2009 | 12:34 AM
beano99's Avatar
New User
the green key light used to come on but now it dnt come on at all.
i took it to honda and they said the immobiliser box on it is faulty. they want 350 quid for new immobiliser box red key and 2 spare keys.
if you say there is no immobiliser wat is causein the injectors not to open and close
it is a uk spec
the ecu is obdII but it uses all 4 plugs is this cause its an auto.
i know older ecu dnt ave immobiliser built in to ecu so could i change ecu to a obdI with a conversion harness. if so wat would b the best ecu to use
Old Jul 17, 2009 | 08:19 PM
redej878's Avatar
Originally Posted by beano99
it is a uk spec
this changes everything.
Old Jul 19, 2009 | 01:00 PM
Qfactor's Avatar
it is a uk spec
send the ecu to Katman, here on this board. he disables immo. on prelude ecu's. it should be the same since yours has the RED learning key as the prelude does.
laurus11
Oct 30, 2015 04:16 PM
Texdriver
Honda CR-V & Element
Apr 8, 2011 05:53 AM
quickspool
Dec 7, 2010 02:08 PM
matt_in_sd
Jan 17, 2006 06:32 PM
