GSR motor Smoking
Old Jul 13, 2009 | 08:43 AM
mouab18c1's Avatar
Icon2 GSR motor Smoking
Alright we'll my buddy as a 92 Civic with a 01 gsr swap and was blowing blue smoke out of his tailpipe. So i changed his headgasket,tb, & waterpump since it was due for anyways and after putting everything back together his car was still smoking. Its been a week now since i had it all back together but im out of ideas of what can be causing all the smoke. I got the head resurfaced before assembling it and it now has arp headstuds torqued down to 80lbs with arp moly lube and no oil leak. i have yet to do a compression test but im on vacation in norcal right now so just trying to gather info and another thing the car runs strong and idles fine. any idea would be great. Thanks guys
Old Jul 13, 2009 | 09:23 AM
acuralovar's Avatar
Default Re: GSR motor Smoking
piston rings ...or valve seals
Old Jul 13, 2009 | 09:40 AM
mouab18c1's Avatar
thats what im thinking but im hoping its not...he's only had the swap for less then 5 months
Old Jul 13, 2009 | 10:01 AM
boostISbest's Avatar
its probably rings but a compresson and leak down test will tell you more. gl with the fix
Old Jul 13, 2009 | 09:53 PM
seanbev24's Avatar
hopefully it's just the valve guide seals, annoying to change but much better scenario then bad rings.
Old Jul 13, 2009 | 10:04 PM
turboacurab20's Avatar
yeah rings or valve seals x2 on hopefully its the vavle seals easier fix
Old Jul 13, 2009 | 10:39 PM
mouab18c1's Avatar
kool thanks or the replies.
Old Jul 14, 2009 | 02:08 AM
K i l l a B e e.'s Avatar
ringy dingys! i hate to burst your bubbles, but with that much smoke coming out i dont think it will be just the valve seals.
Old Jul 14, 2009 | 08:50 AM
mouab18c1's Avatar
smokes only come out when we floor it and when you step on the clutch accelerating or deccelerating
Old Jul 14, 2009 | 01:13 PM
DOHCterJEREMYb's Avatar
piston rings bad, friend has the same problem
Old Jul 14, 2009 | 01:21 PM
mouab18c1's Avatar
what a biotch...my buddy will love me for telling him horror stories about his motor!
Old Jul 14, 2009 | 06:17 PM
94 ls-r's Avatar
I take it he was beatin on it pretty hard. Do a compression test and post results. Maybe we can help more then.
Old Jul 17, 2009 | 02:03 PM
mouab18c1's Avatar
nope..never really slammed on it..maybe once or twice..maybe the previous owner did
Old Jul 17, 2009 | 02:25 PM
94 ls-r's Avatar
Do the compression test.
Old Jul 21, 2009 | 07:39 PM
1ls/vtec's Avatar
Blue smoke is usually Piston rings, if u get on it real hard, a lot of VTEC cars will puff out Black smoke when getting on it, which is fuel.
Old Jul 21, 2009 | 08:11 PM
mouab18c1's Avatar
did a compression test and numbers came out good. cylinder 1-4 210 220 220 210..thinking its valve stem seals
Metal Head
Feb 19, 2009 08:37 PM
mickiemagik
May 21, 2007 06:16 PM
nboost
11
Oct 27, 2006 12:59 PM
kidd_drastic
Jul 20, 2006 04:12 PM
DSRxMilogen
Mar 28, 2005 07:24 PM
