how do u know if u have LSD tranny?
Old Jul 12, 2009 | 07:08 PM
tysonboy's Avatar
Default how do u know if u have LSD tranny?
hi i just bought a car it came with a jdm obd2 b18c... and jdm motors have LSD tranny rite? but on mine i dont see the LSD stamp on the trans?? is it because mine dont have lsd...... how can u tell if u have lsd? thanks in advance
Old Jul 12, 2009 | 07:27 PM
stevenDAtegra's Avatar
Default Re: how do u know if u have LSD tranny?
You could take an axle out and look through the differential and see if it's LSD or not by seeing if you can see all the way through
Do a burnout and see if you leave 2 tire marks lol
Old Jul 12, 2009 | 09:11 PM
tysonboy's Avatar
great thanks i will try it 2mrw...
Old Jul 13, 2009 | 11:18 AM
platinum_rich's Avatar
or you could lift up the front end put it in first and spin one wheel. If the other one spins the different direction then yes you have lsd
Old Jul 13, 2009 | 11:33 AM
itr#1334's Avatar
Not all JDM engines have LSD. You could have a b18c sir which is like usdm gsr. And those lsd was optional.
Old Jul 13, 2009 | 01:03 PM
98ITR747's Avatar
My tranny says LSD right on it then again I have CDM spec.
Old Jul 13, 2009 | 02:12 PM
EFsSuck's Avatar
ALWAYS been my fav
but, back in the day i had a turbo LSVTEC CRX that would lay two tires threw 2nd gear with just a std US spec A1 tranny. diff pin ended up being faulty and shooting threw the case. but it still was not an LSD tranny, and would leave 2 marks. wanna be forsure? look for the pin threw the axle holes...
Old Jul 13, 2009 | 02:53 PM
tysonboy's Avatar
i just did burn out 2day and it lay to burn marks, so does that mean my motor has lsd.. no mods on the engine besides a ebay intake, and a ebay exhaust aswell.... also i want to put it on a dyno to see what # it will put out... i never owned a b18c. my first car was a 2000 si.... thanks for the info
platinum_rich: i will try that aswell... thanks
Old Jul 13, 2009 | 04:04 PM
thundernoodle's Avatar
Just cause it lays down two patches dosent mean it has an LSD. My Prelude would peg-leg sometimes and sometimes not.
Old Jul 13, 2009 | 07:47 PM
racebum's Avatar
pull an axle and see if the bar is in the middle. a flat burn out tells you nothing since an open diff will spin both on an even surface.
Old Jul 13, 2009 | 07:53 PM
migs's Avatar
Remove passenger side axle. Look through tranny hole. If there is a bar in the hole, its NOT an LSD.
Old Jul 13, 2009 | 09:10 PM
tysonboy's Avatar
thanks all...... i will look at it when i do the motor swap... and my car idle real bad dont know why... when i start my car let it idle for 1-2 mins then drive it's fine... then when i really punch on it 2 gear and let go it still ilde at 2-3000 rpm... even when the its in neutral?? wat could b wrong
Old Jul 14, 2009 | 12:41 AM
racebum's Avatar
you have a vacuum leak
Old Jul 14, 2009 | 05:00 AM
tipe R's Avatar
the same thing will happen with an open diff.
Old Jul 14, 2009 | 04:02 PM
tysonboy's Avatar
does anyone have a pix of inside the tranny with lsd... i want to see wat it looks like b4 taking my car apart.... any help will be appreciated...
Old Jul 14, 2009 | 05:39 PM
dc2 specR's Avatar
Hope this link helps Taken from ff-squad.com
http://www.ff-squad.com/technet/how-to/lsdcheck/
Old Jul 14, 2009 | 06:26 PM
tysonboy's Avatar
thanks man....... i will check it out when i do the motor swaps
Old Jul 15, 2009 | 01:17 PM
swapshop's Avatar
funny when ppl say my motor has lsd thats like saying my car didnt pass inspection cuz its out of turn signal fluid
da6xsi06
Transmission & Drivetrain
Oct 6, 2010 04:47 AM
highmilehatch
Jul 18, 2007 06:35 AM
civproject14
18
Feb 8, 2005 12:12 PM
CR-V-tech
Oct 29, 2003 05:37 AM
CRX A4
Apr 5, 2003 04:04 AM
