B17A1 rebuild
Ok, im getting ready to rebiuld my B17A1 in my CRX. Rings are shot and starting to smoke. Prolly going with Type R pistons and hopefully cams to. Im wondering if I put supertech (or some other brand) valvsprings in it, with a rebuilt bottom end (honda rod and main bearings), will it be safe to turn it 9000rpm. And yes i have a 4-1 header and custom sheet metal intake manifold that makes power that high, dyno chart proved that. And some unmentioned spray.
Thanks for any feedback
K i got another ? will type R pistons work in my B17? some people tell me they wont work, but i though all 1.6-1.8 pistons are the same in vtec B's, I thought it was the rods and cranks that changed and not the piston pin locations.
Yes; pretty much any B series piston is interchangeable if the bore is correct. You can calculate the CR here:
http://www.c-speedracing.com/howto/c...c/compcalc.php
look dude the whole reason im on here asking is so i dont have pistons poppin out of my cylinders, I know all this and just figured i would ask if they are the same wrist pin location. Im not a noobie, ive just never built a B17A1 before, ive built plenty of others to know what to look out for despite my age smart ***.
omniman answered all your questions in his 1st paragraph. so just ignore his 2nd paragraph and don't be so sensitive on an internet forum.
and if you weren't a "noobie", you'd know that building a b17 is just like building a b16. only difference is the b17 crank-81.4mm stroke /rod length- 132mm and the b16 has a 77.4 stroke and the rods are 134mm in length. but you probably already knew that
Originally Posted by omniman
you should use the b16a pr3 usdm pistons they have the correct compression height and will have suitable compression for pump gas. and they wont stick out of the hole like the itr ones will and hit the head. i really dont feel like reading your next thread of "why did my pistons hit my head" and if you use the b16 pr3 pistons you dont have to machine the rods to fit them. and the b16 pistons are lighter than the itr. its a win win win.
^^see you're questions were answered
Are you talking "ITR" pistons or "CTR" pct pistons ?
Someone correct me If I am wrong here but don't pr3 pistons have a higher dome than USDM or JDM ITR'S ? I am well aware that pct's are frickin tall as hell.
Different compression height on the ITR piston. 30.23 mm as opposed to 30.00
Angel4768
Oct 4, 2010 12:54 PM
Db1 Supreme
Jan 26, 2006 12:17 AM
luap
Apr 22, 2005 08:14 AM
