Classic Hondas All Pre-1988 Hondas.
Advancing/Retarding Cam Timing
Old Jul 12, 2009 | 07:48 AM
mountainrich's Avatar
Default Advancing/Retarding Cam Timing
Can cam events be adjusted the +/- 4 degrees by purposely putting the timing belt a tooth off?
Old Jul 12, 2009 | 01:40 PM
2ndGenGuy's Avatar
Default Re: Advancing/Retarding Cam Timing
Depends on how many teeth are on the cam gear. I'm sure you can figure out how many degrees by taking 360 and dividing by the number of teeth.
Old Jul 12, 2009 | 02:18 PM
cbstd's Avatar
Changing cam timing by one tooth will make your stock engine run poorly.
If you shave your head, you will need to adjust the cam timing to get it back to the correct relationship to the crank. You would be better served to buy a real adjustable cam gear, they are not expensive.
Scott
Old Jul 12, 2009 | 04:22 PM
2ndGenGuy's Avatar
Being that he's in the Classic Hondas section, he probably can't get an adjustable cam gear. Can't hurt to experiment advancing / retarding by a tooth. Worst case, you'll lose a few HP. My EK1 ran just fine but was clearly down on power... maybe it screws with fuel injected cars worse due to timing / injector events.
Old Jul 12, 2009 | 04:24 PM
Just hoping someone had done it. I'll count teeth.
Old Jul 12, 2009 | 04:49 PM
2ndGenGuy's Avatar
What car do you have anyways? Maybe we can point you more directly to a site with better info.
Old Jul 12, 2009 | 05:20 PM
1983 Civic. CVCC-which I'm trying to get a Weber 32/36 for. It's a 1.5L engine, but I've been trying to ask pretty generic questions. 2-door hatchback. The biggest issue is the tranny. It's automatic and I don't know if it's vacuum modulated or TV controlled. Old vacuum controlled trannys I could buy an adjustable modulator-but I don't know how this one is controlled. Tranny shop simply told me "if it works-it works" and that's it. If it's vacuum controlled, I'd like to get an adjustable modulator for it but that kind of aftermarket part seems impossible. Guess I started on this 20 years too late.
Old Jul 12, 2009 | 05:24 PM
2ndGenGuy's Avatar
It should be a TV cable. If it's not connected directly to the gas pedal, then it's probably connected up at the carburetor. If you don't have the cable connected at either spot, well that would explain your shifting issues.
EG-SIXV-TEC
May 11, 2009 03:00 PM
mike93eh2
Dec 5, 2007 10:58 AM
d15maverick
May 3, 2004 09:14 PM
Red_Si
Apr 20, 2004 07:21 PM
Black96Cobra
Oct 28, 2001 11:06 PM
