Switch from Lock to Accessory I
Old Jul 12, 2009 | 01:19 AM
hadihanifa's Avatar
New User
Icon5 Switch from Lock to Accessory I
Dear All,
I have honda civic 1998, recently I had a problem with the car as it is hard to switch from Lock (o) to accessory I, before it is ok and very smooth switch. Do you know what it cause and what I have to do to fixed it.
Thanks you
Old Jul 12, 2009 | 02:37 AM
Hanmin's Avatar
Default Re: Switch from Lock to Accessory I
give the steering wheel a few jiggles left and right while you turn the key.
The steering wheel is giving pressure to the lock and is making it hard to turn. All you need to do is relieve the pressure.
Old Jul 12, 2009 | 02:45 AM
trustdestruction's Avatar
Maybe your key is worn. I used to have this kind of problem until I went to the dealer and had a new key made. If your key is worn then getting a copy will not help because you'll just have a copy of the worn key. If you go to the dealer they can make you a fresh key by knowing your VIN, for only a couple bucks. Bring your registration inside for proof of ownership. Visit the parts counter.
Old Jul 12, 2009 | 03:33 AM
hadihanifa's Avatar
New User
Dear All,
Thank you for your comments, Steering lock is easy to open by moving a bit to left or right, but half way to accessory I is hard. Is there any other reason ?
Regards,
Old Jul 12, 2009 | 03:50 AM
waaBAAH's Avatar
could jsyt be gunk buildup from you sticking your key in your nose and whatnot.
parts stores carry this graphite lock de icer stuff. its liquid ballbearings in a can. it works wonders for frozen ignition lock tumblers.
Old Jul 12, 2009 | 01:37 PM
Originally Posted by hadihanifa
Dear All,
Regards,
Old Jul 12, 2009 | 01:52 PM
waaBAAH's Avatar
it could be the tumbler gunked up.... buy graphite de-icer
or worn key........ buy new key
or wronglly cut key........have them cut another one.
Old Jul 16, 2009 | 08:12 PM
hadihanifa's Avatar
New User
Ok Thanks Gents,
It was solved by pressing in a bit and push down abit then switch to Accessories I
Old Jul 16, 2009 | 08:52 PM
96DelSol's Avatar
Ok Thanks Gents,
I still recommend you get a NEW KEY.
uses0ap
Apr 4, 2009 06:58 PM
illestsilek
Sep 18, 2007 09:46 PM
carnifex
Mar 3, 2005 01:26 PM
wolfen
Acura TL, RL & ZDX
Jul 17, 2004 06:16 PM
pablo_max
Nov 12, 2002 04:02 PM
