need help on my foglight install..
quick qestion for everyone.. I hope you guys can help me out.. after i installed a foglight on my 92 civic. my rpm starts to bounce on idle and it gets worse when i turn the lights on.. i think i installed the wiring correctly? when i disconnect the brass tip from foglight switch going to the fuse box the rpm is normal again... anyone have a suggestion on whats going on?? is there another place where I can plug the brass tip without affecting the rpm? please help....
the kit i bought is from ebay so theres two sets of wires that came with the kit. first set wich is engine bay wires where i placed the red wire to the battery terminal then from there it goes to a 30amp fuse, then it goes to a relay, it then connects to the foglight then a wire to ground. the second set is ground, then a red wire connecting the two, from there it goes inside to the push button. from there 2 yellow wires connect to a brass female tip where i connected to option (d) wich is the second from the right plug i think thats for the lights. hope this gives you an overall idea on how i wired this thing..
pics would be cool and helpful?
usually i hook up my fogs like this
both fogs grounded
accessory wires spliced into one and pluged into brown one wire plug in engine bay by washer fluid resevoir
wire from underdash fuse box to switch , second from the right on top optional row of spots
from brown one wire plug underdash to relay then from relay to switch
hope somethin helped
both fogs grounded
Ef8crxsi4u2nv
19
May 13, 2010 01:55 PM
crist488
12
Dec 25, 2009 09:22 AM
jaydmjay
13
Dec 24, 2007 06:10 PM
EGPHANTOM
Oct 23, 2004 08:43 PM
