help finishing foglight install!!!!!!!
so i just finished mounting the lights now i just need help with the cabin wiring its that i dont know where to connect each wire the only one i kno is the green connecter which is for the switch
Re: help finishing foglight install!!!!!!!
Did you not have any instructions?
Here ya go. http://www.google.com/search?q=95+ci...ructions&hl=en
Edit: My bad. I see you're rockin a 96. I'll see if the instructions are different.
BOOM!! https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/round-ek-fog-lights-install-process-2172348/
i tryed going off that but didnt help i kno theres 1 wire that goes to the fuse box i kno one is the ground and the green is for the switch i just need to know what to do with the red wire with the brown connector the blue one and the red wire that comes from the fuse holder
ok so green goes to switch red goes to fuse pannel blue wire is ground so i only need to kno where does that red wire with the brown conector goes cuz i think the blue wire connects to the fog light harness in the bay
Colonel Cake Mix
the brown connector should go under the dash above the fuse box where there is a plug... the blue should ground under the dahs and the red should connect to the foglight harness
blue wire/brown connector goes to fuse box red wire/brown connector goes to foglight harness and red single wire to power source? just want to be 100% sure before i go outside and connect everything
On mine the green plug went to the switch. Then there was a brown plug that went to slot 2 on the fuse box under the dash. Then there's a power wire that connects from the fog light harness to inside the cabin harness. The wire coming off the fuse connects to the fuse box under the hood (the two white power wires going into the fuse box) I added mine to one of those. Then there's two ground wires.
Yeah the red connects to the power source (battery) and the brown plug goes under the dash near the fuse box under the steering wheel area
brown with red I believe... I don't remember mine having the brown with blue but it was a couple years ago... sorry
so i traced the red wire and it looks like it goes to the green plug that connected to the switch and the blue wire goes to the relay so would it be blue wire to fuse box and red to harness
i also forgot to mention is that i have a 2000 front and its the 2000 fogs going in so is the wiring diffrent
