92 eg vx swapped gsr
Old Jul 11, 2009 | 09:32 PM
mxracer420's Avatar
Default 92 eg vx swapped gsr
so im drivin home from washington right now and my car has a gsr and is poppin a code for the o2 and has a walboro 255lph and motor is stock just exhaust and ram air were cruisin at 60 barely in throttle and its like chuggin and stutterin once u give it gas it goes away any ideas why lemme know thanks
Old Jul 11, 2009 | 10:49 PM
racebum's Avatar
Default Re: 92 eg vx swapped gsr
a bad o2 can make the car feel choppy in closed loop. the other obvious area to check is ignition timing. verify that you're at 16deg btdc@750rpm and that you don't have a plug, wire, or distributor issue. first replace the o2 or make sure you don't have a wiring issue. once the code clears, drive it. if the problem is still there look into ignition timing areas
Old Jul 12, 2009 | 02:27 PM
lilj95's Avatar
idrivesideways is right you could have arcing issue with the sparkplugs/coilpack
badboyr66
Oct 14, 2007 09:11 AM
japan4racing
Mar 12, 2005 09:06 AM
savedsol
Jan 21, 2005 08:13 PM
bobbysteelz
Aug 4, 2003 05:16 PM
