locking vtec
Old Jul 11, 2009 | 03:02 PM
Teamdiesel's Avatar
Default locking vtec
I am about to check my V2V clearances with my S2S3 cams but don't have any bb's to lock the vtec. What else can i use or how else can i lock vtec to check for this?
Old Jul 11, 2009 | 03:19 PM
Combustion Contraption's Avatar
Default Re: locking vtec
A really small washer that fits in the rocker arm piston bore will work. Basically anything you can fit in there that will push the pin out just a little bit.
32 posts left.
Old Jul 11, 2009 | 06:35 PM
Teamdiesel's Avatar
Originally Posted by Combustion Contraption
32 posts left.
what does that mean?
Old Jul 11, 2009 | 06:36 PM
dlaub25's Avatar
He's retiring his account at 10,000 posts from what I hear.
Old Jul 11, 2009 | 08:06 PM
Teamdiesel's Avatar
why? The info that this man provided to HT is invaluable.
Old Jul 11, 2009 | 08:12 PM
dlaub25's Avatar
Probably tired of all the tools.
Old Jul 12, 2009 | 05:50 AM
Teamdiesel's Avatar
I don't have any helper springs, can I use my supertech springs and do the V2V?
Old Jul 12, 2009 | 07:53 AM
Teamdiesel's Avatar
bump for an answer
Old Jul 12, 2009 | 08:33 AM
flesh199's Avatar
Yes you can use your supertech...It will be harder to turn but you can do it.For locking my rocker arms i put a little plastic wire.
Old Jul 12, 2009 | 10:37 AM
all-mtr-teg's Avatar
bump for an answer
Instead of a BB you can simply swap the 2 pistons in the rocker arms. Put the small piston in the longer piston's pistons and vice versa. For springs, just use some worn out stock springs. Or just the inner supertech springs.
And to CC, I'll be sad to see you retire at the 10K post. A mod should wipe your post count out.
Old Jul 12, 2009 | 05:33 PM
PyroProblem's Avatar
I would use a dummy spring for your measuring. You will have some precision tools under alot of tension if you use real valvesprings.
Match up an outer one and do a mock install. Measuring and turning will be alot easier.
Swapping the 2 rocker arm pistons works for me also!
Ive always wanted to try the pressurized air trick myself. Like a real life engine builder
Old Jul 13, 2009 | 05:10 AM
mar778c's Avatar
Community Builder
Community Influencer
This except he meant to say swap the pins.
Old Jul 13, 2009 | 05:58 AM
PirateMcFred's Avatar
As said before you can swap the pins to lock VTEC. I've also used rolled up wads of paper towel too.
Also if one is expecting to "retire" from a webforum and somehow duck the idiots on the internet then you'll have to "retire" your ISP too.
Old Jul 13, 2009 | 06:30 AM
Teamdiesel's Avatar
I used a small lock washer and it worked perfectly! Thanks everyone for your inputs.
blazzer
Jun 10, 2009 05:56 PM
all-mtr-teg
Aug 19, 2007 07:42 PM
SPOOLINmatt
May 22, 2005 08:28 PM
Cashflo
Sep 18, 2003 09:29 AM
HotRodTeg
Apr 25, 2003 08:19 AM
