Classic Hondas All Pre-1988 Hondas.
1985 CRX is overheating
Old Jul 11, 2009 | 11:30 AM
threehonda's Avatar
Default 1985 CRX is overheating
1985 Crx is overheating, not burning any coolant, just re-gapped all the plugs, new carbureator, new timing belt and waterpump and thermostat. Just replaced the radiator cap, does not overheat on the highway. Only the passenger side fan is running and it stays on for a very long time after the car is shut off. any help is appreciated thx.
Old Jul 11, 2009 | 12:42 PM
mountainrich's Avatar
Default Re: 1985 CRX is overheating
You need to check timing. You then need to figure out A/F ratio if you can. Is this an aftermarket carb or stock? Vacuum line leaks and believe it or not even spark plug gaps or if the timing belt is not zeroed. Is this only idling? Need more conditions and timing #'s and carb data.
Old Jul 11, 2009 | 01:46 PM
threehonda's Avatar
The timing is not an issue. The carburator is stock.
Old Jul 11, 2009 | 03:26 PM
cbstd's Avatar
Correct cam timing is vital on all engines and so I think the suggestion was to check both your cam and ignition timing which is not a bad idea. Even if you think the cam timing is correct,chdeck it again. Then the ignition timing.
Running lean will cause overheating. The easiest way to check for lean condition is to pull a plug and look at its color. It should be a medium brown, anything lighter is too lean. A dark plug is too rich.
How is the coolant system? A fresh Honda thermostat is important. DO NOT save the few bucks of some parts store brand thermostat, get a HONDA part. Lots of people have had issues with non-Honda thermostats.
How is the radiator? It could be clogged.
A bad water pump will sound like a coffee can full of rocks. You did replace the water pump when you replaced the timing belt, right?
Scott
Old Jul 11, 2009 | 04:20 PM
If all the timing's correct and no lean issues, your head may have an air "bubble". This happened to me on another make of car but I have seen it happen. You actually have to "burp" the coolant system. Removing the thermostat and cycling the coolant might help but so might loosening other coolant hoses and seeing if you can get a burst of air out of them. This was messy- being coolant, but the heads finally blew out the air w/ some throttle.
Old Jul 11, 2009 | 05:57 PM
threehonda's Avatar
I will check the timing since its quite easy to do, burping the coolant system sounds like something I could do as well. I can't get the second fan to kick on so I'm going to jump it tomorrow and see if just needs a new relay or something. It was just weird it only overheated in the city on highway the temperature would drop right back down to half-way. Inspected the spark plugs twice and the looked perfectly fine.
Old Jul 12, 2009 | 12:15 PM
threehonda's Avatar
The car is not wanting to start, does anyone have the spark plug order? I think the wires just might be crossed.
Old Jul 12, 2009 | 12:19 PM
threehonda's Avatar
Nevermind they are not crossed
Old Jul 12, 2009 | 02:15 PM
cbstd's Avatar
Originally Posted by threehonda
I will check the timing since its quite easy to do...
If you are having starting problems, it could be cam timing which is NOT easy to check without removing the plastic covers over the cam belt.
Old Jul 12, 2009 | 04:38 PM
E-AT_me's Avatar
the 2nd fan only kicks on with AC.
Old Jul 12, 2009 | 05:17 PM
threehonda's Avatar
Oh the cam timing was not hard to check at all. Take off the alternator belt and crank pulley boom your there. It was fine as well. Just replaced the spark plugs because the other ones were fouled and it started up fine. We did notice that the distributor was retarded and we fixed it. Now i think its getting too much fuel.
jse
Jul 8, 2009 05:03 PM
fogged306
May 19, 2008 12:59 PM
ShinobiLude
Dec 7, 2006 10:23 AM
94accordsedan
Sep 11, 2005 05:26 AM
