Expected More.....
Old Jul 11, 2009 | 10:50 AM
b18cuk's Avatar
Default Expected More.....
Hey guys,
Had the dynoed today and it made 193.5bhp at the flywheel,, redlined at 8600 and vtec was at about 6600.
Has per the title I was expecting more, so i'm thinking of changing the intake manifold and going to either a 68mm or 70mm TB which should help. Any helpful comments, suggestions or opinions on how to get more from this setup would be much appreciated.
The spec is,
Engine Block
B18C4 block (100% completely stripped)
NPR race pistons (B16b design 0.50 oversized)
Pistons electro coated in dry lubricant coating
NPR total seal race series piston rings
ITR oem rods
ARP drag series rod bolts
ARP race series main bolts
Micro polished crank
Full bottom end pro seal kit
Tetra coated racing rod bearings
Tetra coated racing main bearings
Heavy duty thrust washers
Block honed
Block bored
Block decked
Block guard/sleeve saver installed
All threads cleaned and chased
All oil galleries shot through and cleaned
Block hot tanked
Rods and pistons balanced
Block blue printed
Piston ring end gaps set
Outer block painted black
Engine Head
P72 cylinder head
Skunk2 pro series valve springs
Skunk2 pro series titanium retainers
Skunk2 pro series cam gears
Skunk2 pro series stage 3 cams
370 injectors
MLS head gasket
Full race single piece forged steel valves (flat faced to match pistons)
Valves hand lapped and seated
Verton valve stem seals
Skunk style intake manifold with larger inlets to match P72 cylinder head
Head chamber balanced and ccd
Head chamber polished to remove detonation causing material
Head pressure tested
Head machined to remove all protruding surfaces that can heat up
Engine Other
lightweight pulleys
AEM short ram induction kit
JDM 4-2-1 manifold (integra 98 spec import type r)
Custom 2.5" exhaust system
Walbro uprated fuel pump 180 lph
Compression ratio 12.6:1
Engine management
JDM P30 ecu chipped with full data logging and crome software
Old Jul 11, 2009 | 11:12 AM
97CWITR's Avatar
Default Re: Expected More.....
Looks like you're way overcammed!
You have a mid level header...you need a tri-y from hytech, or similar, and you'll see much better results!
Get a velocity stack with a tuned length for your setup as well.
Old Jul 11, 2009 | 11:27 AM
dlaub25's Avatar
I think you may be off when you say your CR is 12.6:1. B18B pistons have a dome volume of -3.4. Even with flat faced valves you would probably have had to take almost .1" of the block and head. How did you calculate your CR? Do you know the volume of your combustion chambers and how much was taken when they decked the block and milled the head?
Old Jul 11, 2009 | 12:56 PM
00Red_SiR's Avatar
All Motor Mentor
Jesus! Try some pro 1's and a better header and see what happens. Why did you choose that type of piston?
Old Jul 11, 2009 | 03:16 PM
Conan the Destroyer's Avatar
that might be a typo. there is no way he didnt have a catasptrohe in vtec with LS pistons and s2pro3 cams.
you need a header.
this reminds me of those "oh **** vtec wasnt engaging" threads
Old Jul 11, 2009 | 04:46 PM
unusual71's Avatar
grab a properly sized header and some more conservative cams and then tune it up. i bet you'll get what you were expecting then.
Old Jul 12, 2009 | 03:26 AM
b18cuk's Avatar
Sorry my mistake, should be b16b for the pistons.
Old Jul 12, 2009 | 03:30 AM
EJ1B18c's Avatar
was this on a dyno dynamics?
Old Jul 12, 2009 | 03:38 AM
b18cuk's Avatar
Yes, one i've been using for years now.
Old Jul 12, 2009 | 03:44 AM
b18cuk's Avatar
Thanks for the advice guys, seems i need a new header. Someone mentioned a hytech header, are they any good? What others should i consider and should i get a 4-2-1 or a 4-1?
Old Jul 12, 2009 | 04:21 AM
92eg_h22's Avatar
vteckidd has a great header that will help you out and keep ur pockets from bein empty
Old Jul 12, 2009 | 04:24 AM
EJ1B18c's Avatar
yea i just fitted vteckidd's narrow header to my motor .going for a retune soon seems to be more torquey already without tuning.
Old Jul 12, 2009 | 04:37 AM
b18cuk's Avatar
Will he ship to the UK?
Old Jul 12, 2009 | 04:44 AM
EJ1B18c's Avatar
yes i got it shipped to ireland no problem. fits perfect other than trimming the fan shroud.
Old Jul 12, 2009 | 05:19 AM
actually, post your dynosheet. cant really say **** until we see that
Old Jul 12, 2009 | 07:58 AM
b18cuk's Avatar
Here you go..
Old Jul 12, 2009 | 08:41 AM
OH_1fstgsr's Avatar
A better header should be helpful, Hytech or SMSP. You've spent a lot of money on your block and head why skimp on the header. Call either of these guys to get you a properly sized header for you application.
What is the flow rate of you head?
To get the most out of your S2PRO3 cams I believe you would need around ~300cfm. Or change to PRO1's.
Also you can give a little more detail about the "Skunk style intake manifold".
Old Jul 12, 2009 | 09:15 AM
b18cuk's Avatar
The intake manifold is a skunk2 copy, probably not that great. which is why i'm going to change it for a genuine skunk2 intake.
Bought the motor with this already done, not ideal if i need to find anything out, but i do know who built the engine so that helps.
Old Jul 12, 2009 | 10:21 AM
Zaraki's Avatar
Pro 3's...? Why?
Old Jul 12, 2009 | 10:28 AM
b18cuk's Avatar
Originally Posted by Zaraki
Pro 3's...? Why?
Were in when i bought the motor.
Old Jul 12, 2009 | 06:07 PM
NAcoupeNA's Avatar
Pro1's would do great with this set up
Old Jul 13, 2009 | 05:13 AM
mar778c's Avatar
Community Builder
Community Influencer
OP, my experience with dyno dynamics is they indicate low. To me it looks like you maybe could set vtec a little lower like at 6k but I would bet money that thing will haul. I'm talking 12's on slicks.
Old Jul 13, 2009 | 07:03 AM
b18cuk's Avatar
I can't fault the engine, responsive as hell. Lowering the vtec is one of the things i'm going to do, along with other things that have been suggested. I had thought of lowering the vtec to 5800, but it may be a case of seeing what works best.
killalude
May 3, 2010 08:58 PM
ghostrider dc2
Oct 29, 2006 03:00 PM
CRVTEC0WNZJ00
Oct 13, 2004 03:44 PM
Red99CivicSi
Jul 13, 2003 10:36 AM
sweet
Apr 21, 2003 06:57 AM
