1998 ex swap question please help
im helping a buddy on a sleeper project we are swapping in a obd1 ls auto into his 98 coupe i was wondering what type of mounts i would need to complete the swap do i need to get swap mounts or can i use the mounts off of one of the engines any info would be great.
i just did this same swap into my 98 civic. except its a gsr motor. i use the rear t bracket from a 99-00 si. the transmission side i used the stock one and the motor side i had to order a b series into ek mount.
99-00 si back t mount, drivers side 99-00 si "engine" mount, re-use the 4 mount on the two side of the chasis mount. Any b-seriers a/c mount unless you want to run a/c then you'll have to grab a del sol vtec(b16a3) a/c mount in order for you to re-use the factory d-seriers a/c unit.
