automatic to manual conversion
has anyone done a automatic to manual conversion before?
i know that im going to need a pedal asembly and then the shiftlinkage.... and then do some wiring so that is will start/get the key out.... saying that the car in no longer put into park
but really how hard is it? should i even try?
let me know what you think thanks
Pretty simple if you can turn a wrench man. The most difficult part is the pedal assembly. Just take out the whole pedal assembly (minus the accelerator pedal). You'll have to drill a hole in the firewall for your clutch cable. Then it is just a matter of jumping a couple of wires in the console by the shifter and then running 2 to the bay for reverse lights.
Its really quite simple once you get past the pedal assembly.
Parts needed:
Transmission
Flywheel with bolts
Clutch
Clutch Cable
Shift linkage and Shifter
Now get to work.
Parts needed:
Transmission
Flywheel with bolts
Clutch
Clutch Cable
Now get to work.
sounds good i was planning on buying a crx but it automatic.... ive taken out the pedal assembly before on on a crx and its not fun... i just wanted to some insight on the wireing aspect....
thanks for the post any more help will be appreciated..
dont forget the rear trans mount/bracket and the clutch cable hole should already be there its there on my hatch and sedan and theyre both auto...im getting ready to do this on my sedan wont be messin with the hatch cuz im swaping it
Ah yes, forgot about the rear mount. And the hole was already there for the cable? That's f'd up. There wasn't a hole on my 89 sedan.
and here u go http://www.gassavers.org/showthread.php?t=1033 i dont think the link in the FAQ works anymore
yeah its there on my 90 sedan...pretty sure my hatch has one too its a 91 maybe there was a plug u didnt take out??? thats weird i did this swap in my old 90 prelude si i had back in high school and all the stuff was there just plugged up and had blank plates bolted on that came right off....it makes sense for honda to just use a universal firewall with everything auto/manual there already so theres not a diff firewall for auto or manual cars its all about saving money lol
honestly the swap is no that hard, me and a friend knocked it out in about 7 hours.
as mentioned already the pedals are the worst of it. i did it on a 88 hatch and i had to drill a whole in the firewall for the clutch cable. wiring is easy. def check the faq there is a few good walkthroughs in there.
how are people mounting the shift linkage in the cabin? there is no holes stock is it ok to drill them if so what to do so water and debree dont get into the cabin
