are dual valve springs on b16 the same as itr dual valve springs???
ok im planning on putting 2001 itr cams in my b16 and want to do it right the first time then be sorry when a bent valve happens. some people say that the dual valve springs on the intake side of the b16 are the same as the dual valve springs on the itr (intake and exhaust sides). i was looking at the part number from acura and honda and it shows different part numbers. can someone confirm this?
i would assume the itr valve springs are strong than the b16 ones since itr cams are more aggressive
Negative, parts are different. What people usually do is use the B16 ones on the exhaust side and ITR ones on the intake side. I think you got your information confused.
do teh ITR cams, dont beat on it/ hit high revs, until you get some aftermarket springs. check the HT marketplace, there is always someone selling **** for the B16
92integraVTECgsr
Dec 29, 2020 09:15 PM
mynameizstitch
Jul 10, 2009 07:09 PM
charjacq
Sep 24, 2002 04:31 PM
