97 civic fan speed blower switch only works on 3,4
Old Jul 10, 2009 | 05:52 PM
shuiyuan's Avatar
Icon3 97 civic fan speed blower switch only works on 3,4
i was driving my car today when i was on "2" fan blower speed and suddenly the fan stopped blow any air, so i moved the switch to "3" and it started to blow the air at "3" speed again.
now i try to go back to 1 or 2, there is not air come from the vents. so its only work on 3 and max speed.
is this the climate control head unit failure or the blower?
Old Jul 10, 2009 | 07:03 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: 97 civic fan speed blower switch only works on 3,4
Most likely it is the Blower Motor Resistor.
Old Jul 10, 2009 | 07:21 PM
joeyd161's Avatar
Had this happen to me this winter but only max would work, replaced the Blower Motor Resistor and all was good.
Old Jul 10, 2009 | 11:35 PM
shuiyuan's Avatar
do you know the part # of the resistor? thanks
Old Jul 10, 2009 | 11:42 PM
geneeunit's Avatar
part number for 96-98 is:79330-SR3-A01
its different for 99-00
and since i didn't even know the blower was supposed to turn on for 1,2 i took out my resistor and had a look.. im assuming this is what you don't want it to look like.
EDIT:: thanks 'N3va3vaSatisfi3d' looks like i need to go order some parts.
Old Jul 11, 2009 | 02:49 PM
shuiyuan's Avatar
wow, thanks for the replies
so your didnt work at 1 and 2 but only 3 and 4 just like my car is doing now?
i will just order the #79330-SR3-A01 will fix the problem? thanks geneeunits!
Old Jul 11, 2009 | 02:54 PM
shuiyuan's Avatar
Old Jul 11, 2009 | 03:30 PM
geneeunit's Avatar
should fix it, and its super easy to take out too.. probably 5mins of work, including a 4min. break.
thank you, i didnt even know 1 and 2 were supposed to turn the blower on. haha.
Old Jul 22, 2013 | 01:47 PM
guroove's Avatar
I'm just resurrecting this thread because the car I just bought has this issue. How does one access these resistors?
Old Jul 22, 2013 | 01:49 PM
Former User's Avatar
Remove glove box.
Old Jul 22, 2013 | 01:51 PM
guroove's Avatar
Very excellent! Thank you!
Old Feb 20, 2015 | 12:35 PM
Albert forline's Avatar
So i am having this problem now, Would the Resister cause my blower motor to make a funny sound as well as not working on 1 or 2?
Old Feb 20, 2015 | 12:36 PM
Please help with my issue, i need to know if this would cause a funny noise in addition to the first 2 heat settings not working. Also if this could damage my car.
Old Feb 20, 2015 | 12:37 PM
Probably separate issues.
Probably not.
Old Feb 23, 2015 | 01:34 PM
Thank you! So if worst comes to worst do you think it would be the actual blower motor or something clogged up?
Old Feb 24, 2015 | 12:01 PM
Jimi Hondrix's Avatar
Might be the blower motor's plastic fan wheel wobbling and hitting the sides of the motor's casing. Easy to remove fan/ blower motor.. search youtubes.
ferio_11
Dec 2, 2017 05:05 AM
_EF9
Jul 29, 2013 05:37 PM
///MPower
Jan 27, 2010 08:27 AM
kpjo4
11
Jun 13, 2009 05:13 PM
