Kre8speed's dd N/A build plan
Old Jul 10, 2009 | 01:05 PM
kre8speed's Avatar
Default Kre8speed's dd N/A build plan
Ok so I am trying to come up with a build plan for my self and after much research I think that i have one for my dd.
This is going to be a poor man's type r:
B18c1 GSR Block
Stock rods
OS P30 81.25mm over bore pistons
3 layer oem head gasket
arp head studs
new p72 oil and water pump
oem rings
oem bearings
balance/ micro polished cranke/hone
should have 11.32:1 comp. with this set up.
B16a head
mild port
type r intake manni and TB
hondata IM gasket
skunk 2 stage 2 cams and vt
3 angle valve job.
new oem valve seals
Ecu
hondata s300
I am looking into more for the motor but wanted to get your ideas on my build plan.
I am looking for a good header for this motor. I need some ideas but I am thinking of running a jdm typr r 4 into 1 header (for now). May look into a hyltech type r header or smsp. (if money in there for the cost of those headers)
I want to do a 2.5 exhaust set up.
Please I am putting this build together things can change at any time I just want some feed back.
Thanks
Kris
Old Jul 10, 2009 | 01:12 PM
kre8speed's Avatar
Default Re: Kre8speed's dd N/A build plan
Since I sold my crx this motor will be going into a EJ1 or a EJ8 I haven't decided which one yet but leaning towards a EJ8. Keep in mind though this is a build plan I am not building this motor yet. I like to come up with a solid build plan before I spend money. I just like to get input.
Kris
Old Jul 10, 2009 | 02:34 PM
ph3ar's Avatar
Its been done a million times. It will be fun to drive, and dependable when assembled/tuned correctly.
Old Jul 10, 2009 | 02:36 PM
kre8speed's Avatar
Yeah I have seen many of these builds I just thought I would put mine on here and get feed back.
Thanks
Kris
Old Jul 10, 2009 | 02:47 PM
00Red_SiR's Avatar
All Motor Mentor
Get oversized pistons and have the block bored to match.
Old Jul 10, 2009 | 03:11 PM
Conan the Destroyer's Avatar
put it into an EJ8 for sure, without a doubt. leaps and bounds nicer than anything from the EG family. do the SMS header, if not for anything, for the ground clearance. i realize they are expensive, but this is something that you get something to show for your money spent. youll always have it, and itll always last. i dont think a grand is too much for a header that you could be buried with. leave the AC and PS and youll basically have an EM1 with a lot more *****.
Old Jul 10, 2009 | 03:41 PM
UncleD's Avatar
Where do you want your power to be had? What is your max rpm that you want to rev to?
Old Jul 10, 2009 | 04:48 PM
kre8speed's Avatar
power wise I would like to see between 180 and 200 whp. I am using a gsr tranny with a type r lsd and mabe a type r final. I do want to get the smp but I will prob. just start out with the type r 4 to 1 for now. I would like to keep the stock bore as well. I am going to daily drive and want to keep thing simple. RPM wise 9k is good, and track times I would be happy with a mid 13 down the 1320. I am going to keep full interior and a/c and p/s. I am planing on a wire tuck and for the most part a stock looking exterior.
Kris
Old Jul 10, 2009 | 05:33 PM
ph3ar's Avatar
You could definately achieve those goals with a overbore to 81.50 and a nice header.
Old Jul 10, 2009 | 05:35 PM
UncleD's Avatar
I might consider a Toda B or even the Pro1 for your camshaft selection. The Toda would be easier to tune, but the Pro1 has more potential....just depends on your tuner. My old roomate realized "better" results when he switched from B. Crower 2's to S2S2's. Not saying they are bad, but I do believe you could make more with a different camshaft.
00Red_SiR's Avatar
All Motor Mentor
You will not get a good ring seal with stock bore sized pistons. If you want to do this build properly, go with 81.5 mm bore or do it the way you want to and put up with the poor results.
Old Jul 10, 2009 | 05:58 PM
kre8speed's Avatar
ok so if i did go with 81.50mm pistons than what pistons would you guys use. And why wouldnt I get good ring seal?
Kris
Old Jul 10, 2009 | 06:01 PM
kre8speed's Avatar
I was going to go with the skunk 2 series two but I liked the bc cams. But like I said I want to do this right and if there is a chance to make alittle more power than I am all for it.
kris
Old Jul 10, 2009 | 06:20 PM
Kris
forget 81.5. this is a reliable daily, so go to honda and order the "OS" P30. its 81.25, comes with honda rings and they are about 150ish-200 for 4. its what you need to freshen up an 81mm block. that way you dont have to dick around with RS.
Old Jul 10, 2009 | 06:25 PM
kre8speed's Avatar
Ok that sounds good and that is a good price for the pistons and rings. I can see that alittle of en overbore is going to straiten up the bore for better ring seat and seal. point taken.
Thanks
kris
Old Jul 10, 2009 | 06:50 PM
kre8speed's Avatar
Also what is a good place to get oem parts from honda online?
Kris
Old Jul 13, 2009 | 08:31 PM
kre8speed's Avatar
bump!!
Old Jul 14, 2009 | 03:41 AM
alterdcreations's Avatar
majestic honda
HondaAutomotiveParts.com
Old Jul 14, 2009 | 04:08 AM
EK9 CTR's Avatar
Majestic Honda; no doubt.... I've dealt with them before on numerous occassions... The best customer service relations i've ever seen from a dealership...
Old Jul 14, 2009 | 06:38 AM
killerpenguin21's Avatar
The p30's having been a jdm piston are available through majestic?
Old Jul 14, 2009 | 06:53 AM
morgan@synapse motorsport's Avatar
Hmotorsonline sells the p30 pistons at a great price and has them in stock.
Old Jul 14, 2009 | 09:13 AM
kre8speed's Avatar
Yeah I saw that but they only have the p30s in stock bore though.
Kris
kre8speed's Avatar
Originally Posted by alterdcreations
majestic honda
thanks
Kris
Old Jul 14, 2009 | 07:50 PM
numberone's Avatar
I used arp rod bolts in my B18C for a little extra reliability. What valvetrain and injectors you gonna run?
Old Jul 15, 2009 | 04:54 AM
aayuub*ef*8-SiR's Avatar
CTR pistons 81.50 with npr RACING rings (whitebox)NIPPON RACING
ITR camshafts, with supertech valvatrain/ flat eco valves also supertech
ARP head studs/rodbolts
prelude olskool h22a injectors (compared to the rc 310cc)
if? u r interested in a piston kit with rings/honda or O.E.M. camshafts email me at aayuub09@yahoo.com
Your Name
233
Mar 12, 2014 02:45 PM
CRISxMOB
Feb 4, 2012 09:37 PM
datflyboy
15
Dec 6, 2010 05:04 PM
99SlammedCivic
57
Jul 1, 2008 04:48 PM
iHave2Cams
Mar 3, 2004 11:14 PM
