wtb: 92-95 civic auto to manual conversion tranny mount.
i have that body mount from a manual trans car. all you have to do is drill out the spot welds on your body mount, do the same on this mount, and then weld it to your car. then you just use the regular mount that is coming with the trans.
$10 shipped for you if you want the body mount. a little more work than just an aftermarket mount, but should end up being cheaper.
nope, he's looking for a custom (aftermarket) mount that allows you to put a manual trans into a car that came stock with an auto trans. the body mount is different, so you either get a conversion mount or change the body mount for it to work.
here is an example:
http://hasport.com/shop/product_info...roducts_id=115
here is an example:
redrocket
Aug 11, 2010 09:08 AM
stackz
Nov 15, 2006 01:04 PM
gsp ej1-em1
Feb 26, 2006 06:52 AM
