88-91 Civic Recall
Here is one recall from the site http://www.recalls.gov/nhtsa.html .
There are other recalls related to reflectors and corner lights.
Visit the site and select your model and year and so forth.
You can see all the recalls for your vehicle. I found 8 for the 91 civic.
Only one was fault of the actual American Honda Motor Co.
Other recalls were by other companies who manufactured aftermarket parts.
Heres one in regards to seat belt failure...
Make: HONDA Model: CIVIC
Model Year: 1991
Manufacturer: AMERICAN HONDA MOTOR CO.
Mfr's Report Date: MAY 16, 1995
NHTSA CAMPAIGN ID Number: 95V103001
EA94035,PE94093
NHTSA Action Number: 2 Investigations found View
Component: SEAT BELTS:FRONT:BUCKLE ASSEMBLY
Potential Number of Units Affected: 3700000
Summary:
THE FRONT SAFETY BELT BUCKLE RELEASE BUTTONS CAN BREAK. THESE RED PLASTIC RELEASE BUTTONS ARE MARKED "PRESS." IF A BUTTON BREAKS, PIECES CAN FALL INTO THE BUCKLE ASSEMBLY CAUSING THE BUCKLE TO OPERATE IMPROPERLY.
Consequence:
THE SAFETY BELTS WOULD NOT PROVIDE ADEQUATE PROTECTION TO AN OCCUPANT IN A VEHICLE CRASH.
Remedy:
OWNERS SHOULD PROMPTLY CHECK THE CONDITION AND OPERATION OF BOTH FRONT SAFETY BELT BUCKLES. CAREFULLY INSPECT THE RED RELEASE BUTTON FOR ANY BREAKS OR CRACKS. CHECK THAT BOTH BUCKLES ARE OPERATING PROPERLY BY INSERTING EACH LATCH PLATE INTO ITS BUCKLE, TUG ON THE BELT TO MAKE SURE THE LATCH IS SECURELY LOCKED, THEN PRESS THE RELEASE BUTTON. THE LATCH PLATE SHOULD POP OUT OF THE BUCKLE WHEN THE BUTTON IS PRESSED. IF EITHER RELEASE BUTTON SHOWS ANY SIGN OF BREAKAGE OR CRACKING, OR IF EITHER BUCKLE FAILS TO OPERATE PROPERLY, PROMPTLY CONTACT YOUR AUTHORIZED HONDA/ACURA DEALER TO SCHEDULE AN APPOINTMENT TO HAVE THE BUCKLE REPLACED OR REPAIRED, FREE OF CHARGE. THE MANUFACTURER IS DEVELOPING A REMEDY DESIGNED TO PREVENT THE FAILURE OF THE BUTTONS THAT ARE NOT CURRENTLY BROKEN.
Notes:
SYSTEM: INTERIOR; SEAT BELTS; BELT BUCKLES. VEHICLE DESCRIPTION: 2-DOOR, 4-DOOR AND 5-DOOR PASSENGER VEHICLES EQUIPPED WITH SAFETY BELTS MADE BY TAKATA CORPORATION. NOTE: IF YOUR VEHICLE IS PRESENTED TO AN AUTHORIZED DEALER AT AN AGREED UPON SERVICE DATE AND THE REMEDY IS NOT PROVIDED FREE OF CHARGE WITHIN A REASONABLETIME, PLEASE CONTACT HONDA/ACURA AT 1-800-999-1009. ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-800-424-9393.
Model Year: 1991
EA94035,PE94093
Summary:
Consequence:
Remedy:
Notes:
Yup its a ticking time bomb. Better give it to me for $3.50 and concider your self lucky. But really just search or call your dealership they will tell you its the law.
not really, just typical ish was really the only problem but no recalls that ive ever heard of. just stuff like cv axles head gaskets cooling and some electrical issues but nothing serious
Yes all hondas have lifetime free replacement on seatbelts. They might just not be the same color when you get them replaced. Also the ignitor those things just go out I'm sure not many 88-91's are still running the stock one. Also main relays go out all the time from weather change to driving conditions.
but then again, i dropped a new motor in
Do the seat belts have pretensioners like newer cars? My civic was repaired from an accident but the seat belt sometimes sticks (the lower waist portion).
Vehicle Make / Model: Model Year(s):
ACURA / INTEGRA 1986-1991
ACURA / LEGEND 1986-1990
ACURA / NSX 1991
HONDA / ACCORD 1986-1991
HONDA / CIVIC 1986-1991
HONDA / PRELUDE 1986-1991
Manufacturer: AMERICAN HONDA MOTOR CO. Report Receipt Date: MAY 24, 1995
NHTSA CAMPAIGN ID Number: 95V103001 EA94035,PE94093
NHTSA Action Number: 2 Investigations found (View)
Potential Number of Units Affected: 3,700,000
Summary:
Consequence:
Remedy:
Notes:
ACURA / NSX 1991
Summary:
Consequence:
Remedy:
Notes:
Sierrakat
Honda Civic (2006 - 2015)
Apr 18, 2018 06:23 AM
speedtrash2
Feb 16, 2007 08:46 AM
