code 41 on eg with b18b1
Old Jul 9, 2009 | 07:32 PM
v8killaz's Avatar
Default code 41 on eg with b18b1
been driving this car for along time and prev owner said because the 2nd o2 senror was not plugged in it was throwing the code
i just checked it using the sticky cel thread up top and it throwing code 41
4 long flashes 1 short
from what the thread states its the primary o2 sesor heater wire
im confused now, whats the problem and what are the symptoms
the car runs and starts, and drives fine but idles funny(up and down a bit)
Old Jul 11, 2009 | 06:04 PM
v8killaz's Avatar
Default Re: code 41 on eg with b18b1
ok guys i guiess the o2 sensor wasnt plugged in now i plugged it and idle is kind of fluctuating worse then before, but still good enough any ideas about idle
and what about the second o2 sensor, doesnt that cause a cel or no if its unplugged
Old Jul 11, 2009 | 07:11 PM
goldfinger93030's Avatar
first check and see if the plugs are loose and if not then check for a leak in the exhaust upstream of the primary o2 sensor .... and the secondary o2 sensor should have nothing to do with the code
Old Jul 11, 2009 | 08:22 PM
lsfreak90's Avatar
i have the same swap and the same code being thrown
Old Jul 11, 2009 | 09:46 PM
v8killaz's Avatar
Fixed, prev. Owner said engine wasobd2 but it was obd 1 I beileve and the wiring was all ducked up so I fixed the wiring on the 4 wire o2, eg cx had 1 wire o2 so I had to add wires from ecu
ls freak pm me if u still lost u got b18b in eg right
Old Jul 13, 2009 | 08:55 AM
so you got rid of your code? what was the problem?
Old Jul 13, 2009 | 09:55 AM
Former User's Avatar
Bad O2 sensor wiring.
Spug
May 26, 2012 12:15 AM
PWRDbyHseries
Feb 22, 2006 04:53 PM
Mr. Softee
Dec 31, 2003 02:46 PM
tub_sephiroth
Jun 11, 2003 02:21 PM
Qwikrex
Jun 22, 2002 12:52 PM
