g series plan of attack
Old Jul 9, 2009 | 06:43 PM
95accordluver's Avatar
Default g series plan of attack
ok so heres the low down i am lookin for advice i made a bulid sheet and this what it looks like let me know if i forgot somthing i know i did any advice on brands etc. and some tech advice from people that have done a g swap
pistons= $116.71 85mm je pistons
header= $38.50 no name h seires header
cams=$463.13 brian cower stage3 h series cams n/a
cam gears=$236.99 skunk2 pro seiries cam gears
valve retainers=$226.80 skunk2 titanium
valve springs=$243.60 skunk2 tuner seires
throttle body=$333.60 billet 66mm
intake mani=$404.40 skunk2 mani
rods=$336.00 eagle forged rods
intake=$220.93 k&n typhoon cold air intake
thanks in advance
Old Jul 10, 2009 | 04:48 AM
tamadrummer1120's Avatar
Default Re: g series plan of attack
You asked if you were missing anything
Were you planning on getting new rods??
But besides that, it looks to be a sick build!
Old Jul 10, 2009 | 09:08 AM
hondamark35's Avatar
maybe just an opinion... with $2400 in upgrade parts (excluding original cost of engine, new seals and gaskets, and machine shop/builder cost...) may as well put some good headers on it.
what do you plan to use for engine management (ECU/tuning)?
which injectors, and other fuel system components will you use?
are you using an F22 bottom end? i'm guessing H22 head...
Old Jul 10, 2009 | 06:02 PM
ummm well for the header i went cheap because im gonna go boost ill only use it n/a for a short amount of time and as for rods what should i use.
i am using the f23a1 bottom end with an h22a1 head.
Old Jul 10, 2009 | 06:28 PM
striker81's Avatar
Polish the crank.
Old Jul 10, 2009 | 06:58 PM
i hear you on the header, that makes sense.
you may have some trouble putting 85mm pistons in a block with 86mm bores... you can look for K20A fitment pistons as far as aftermarket goes. i don't think there's a lot of support in that area for the F23A1. either way, K20A forged pistons turned around exhaust side to intake side w/valve reliefs enlarged should work.
so are those cams good for boost? the little i've learned about aftermarket cams, there's usually a specific type for boost.
also, you'll need to stick to dished pistons if you plan on turbo in the future. even a flat piston in the F23A will be too much compression for a typical turbo build.
Old Jul 10, 2009 | 09:18 PM
oh good to know i didnt relize they were 86mm i feel really dumb
and thanx for the input on the compression stuff im new to this so everything helps i will look into the cams.
keep the advice coming
Old Jul 10, 2009 | 10:24 PM
slammed em1's Avatar
how much to do the swap itself..i plan on doin the same with a few frieds but i need to know wat i need to do to make it it work....
Old Jul 10, 2009 | 11:20 PM
depends i already had both the block and head my accord has the h23a1 so i am just gonna put the head on that i got from a buddy for 150 bux so it just depends on what u have.
Old Jul 10, 2009 | 11:22 PM
and as for an ecu would a chipped p72 work after a tune?
skunk2.com
Performance
May 29, 2014 09:33 PM
jesse209eg
Mar 18, 2013 06:08 AM
95civickid
Oct 27, 2008 02:52 PM
