Rotating assembly balancing?
Old Jul 9, 2009 | 06:10 PM
all-mtr-teg's Avatar
Default Rotating assembly balancing?
I've got a build I'm assembly for a friend. He took his block, crank, rods, pistons and harmonic balancer to a machine shop. He didn't have his lightened flywheel or clutch yet, so the machine shop balanced the rotating assembly with just the harmonic balancer. Can the rotating assembly be balanced correctly without the flywheel? I know the flywheels are internally balanced but won't the front to back weight be affected by not having the flywheel and clutch attached?
The machinist I usually go to always ask for the flywheel, clutch assembly, rings and bearings when he balances my assemblies.
Old Jul 9, 2009 | 06:26 PM
88Hatchy's Avatar
Default Re: Rotating assembly balancing?
As long as the flywheel has been balanced it should be fine.
Old Jul 9, 2009 | 06:48 PM
Ok, I think I remember now, Honda's are internally balanced, therefore flywheels don't affect the balancing process right?
Old Jul 9, 2009 | 06:49 PM
dlaub25's Avatar
Does front to back weight even come into play? If that is the case than the flywheel end of any engine would most likely be a good deal heavier.
I've always been curious of how they go about balancing a IL-4. My old machinist told me it is somewhat eaiser than a V6/V8 and that bobweights aren't used. Can anyone elaborate?
Old Jul 9, 2009 | 06:59 PM
No bobweights on I-4 cause the rods and pistons don't rotate on the same planes as a V6/V8. The bobweights offset the reciprocating weight of the pistons and rods if I recall correctly. My machinist matches the pistons to +/- .5 grams, then the rod's big ends, then the rod's small ends.
For grocerry getters, +/- 1 gram is acceptable.
Old Jul 10, 2009 | 04:57 AM
dlaub25's Avatar
I'm still fuzzy on the concept. I guess I just don't understand why the weight of the pistons and rods isn't necessary when balancing the crank. I know one of the major differences on a V8 crank is that there are 4 crank pin angles @90* angles. (not sure if that's the right terminology) Where on a I-4 there are only 2 180* apart. Correct? But then there are also flat plane V8s. They use a crank similar to a I-4, would they share the same balancing characteristics as an I-4. Found a good website that shows different types of crankshafts if anyone is interested. Crankshaft Designs That's where I got most of the info from.
Old Jul 10, 2009 | 09:04 AM
NAH2B's Avatar
yes it is a good idea to balance the damper, flywheel and clutch along w/ the crankshaft. together or seperate, either is fine.
balance the rods/pistons to match by weight
good aftermarket rods/pistons are usually dead on and wont need adjustment.
i have found brand new oem honda dampers to be out of balance, always a good idea to check them.
Old Jul 10, 2009 | 01:41 PM
I remember reading that link a while back, but couldn't remember the link when I was recently looking for it. Thanks for posting that up.
Old Jul 10, 2009 | 01:48 PM
dlaub25's Avatar
alowe336
Honda Civic (2001 - 2005)
Mar 19, 2017 07:29 PM
trecool44
May 20, 2007 07:15 AM
See Are X
Jun 22, 2003 02:08 PM
pentaq
Apr 29, 2003 04:36 AM
wutangben
Sep 4, 2002 11:51 AM
