biggest problems with obd2 swap
Old Jul 9, 2009 | 01:21 PM
tealchief's Avatar
Default biggest problems with obd2 swap
A buddy of mine is getting a ef and his old integra is totaled so he's taking the c1 from it and wants to put it in a hatch. if anyone has any experience with this swap can you tell us what are some thing that will ake this a harder swap than an obd1 engine
thankyou
Old Jul 9, 2009 | 02:04 PM
dephtone's Avatar
Default Re: biggest problems with obd2 swap
The only difference beteen obd1 and obd2 is the ECU and the distributor. All you will have to do is run an OBD1 distributor and a OBD1 chipped ECU, and it will just be like any other swap.
Old Jul 9, 2009 | 02:08 PM
D16SiHatch's Avatar
its not a big problem, just run it with an obd1 p72 ecu. plus you dont even need to get a new distributor. obd1 and 2 are the same internally so all you need to do is swap over obd1 plugs.
jolt-tsp
Apr 30, 2005 12:46 PM
stevieteg
Jul 8, 2003 03:09 PM
gearhead313
Mar 2, 2003 01:44 PM
KTeller8
Aug 25, 2002 09:13 PM
