Bosch injectors - ford racing green tops
Old Jul 9, 2009 | 12:52 PM
Y4 Warrior's Avatar
Default Bosch injectors - ford racing green tops
Well im looking for some injectors for my future turbo setup. Came across these bad boys, nice price tag aswell.
But these injectors look like they will need to be modified in order to fit the fuel rail. i was also trying to compare size between these & the DSMs, & these green tops seem to be a little longer but only where the spray nozzle part is.
These green tops look appealing to me because they're already saturated injectors, but they will have to be modified. Im afraid to wire in resistors/resistor box for DSMs, i know it looks easy, but heard alot of people have problems...
I also found a company that already sells the injectors milled here just to get an idea as to what needs to be modifed on the injector...
Old Jul 9, 2009 | 04:28 PM
SilverEk3dr's Avatar
Default Re: Bosch injectors - ford racing green tops
pls do yourself a favor (and save hundreds in the process) & find a hobby that comes with directions
Old Jul 9, 2009 | 04:40 PM
jhammond_82's Avatar
Reject Papi
do YOURself a favor, and sshhhhh. people are trying to learn here buddy. actually, i'm not sure about those ebay ones. i'd honestly be interested in buying a set of them. as for the dsm injectors, they are pretty easy to wire up. there is a how to in the forum. if you're not sure how to do it still, ask a buddy to help.
Old Jul 9, 2009 | 10:03 PM
Y4 Warrior's Avatar
Ok not the answer i was looking for but thanks anyway...
Old Jul 9, 2009 | 10:08 PM
Y4 Warrior's Avatar
I have seen alot of the how to threads around. fact is i just dont want to have to wire in resistors/resistor box, but with these green top injectors, i may need to wire in some EV1 injector connectors cause im not sure if the OBD2 connectors will fit.
Im starting to think, to get these injectors to work/fit properly its going to be too much work & id be better off with DSMs or Precisions (cheaper than RC). much rather DSMs cause they even cheaper.
Im trying to find injectors locally. Im in australia, so plenty of fords around. i was also looking at the RX7 NA 460cc injectors, but they are hard to acquire because it seems everyone uses them to upgrade their fuel setup...
Old Jul 10, 2009 | 04:47 AM
Should have mentioned that before. If u were in the us I would say stop being cheap and buy some injector dynamics injectors. Although being down under just get some dsm's (if you can) and wire in a resistor box. Its VERY easy.
sevenj
May 21, 2008 04:50 PM
Schister66
Apr 26, 2006 08:36 AM
darkblue1998ls
May 20, 2005 04:46 PM
stockhatch91
Nov 22, 2004 03:59 PM
b18bturbo
May 14, 2003 10:44 AM
