b16 tranny or gsr tranny?
Old Jul 9, 2009 | 12:42 PM
rick_rabies's Avatar
I'm not Rick!
Default b16 tranny or gsr tranny?
gsr motor with 10lbs. some say dont bother with swapping to a b16(sitting on my garage floor) i know the gears are shorter in the b16, but the final drive is gay. which one should i put the lsd in?
i thought about this. put gears 1-2-3 from the b16 in the gsr tranny and the lsd. yeah good idea?
and put the 1-2-3 gears from gsr into b16 trany and sell it or keep it when i go to 20lbs and blow trannys up?
this question is related to a turbo so thats why i ask here
Old Jul 9, 2009 | 12:53 PM
gsrauto98's Avatar
Default Re: b16 tranny or gsr tranny?
b16 gears are kinda short for a boosted car, i would leave the gsr trans in there and not touch it. IMO
Old Jul 9, 2009 | 12:54 PM
I'm not Rick!
so keep the b16 for a backup and put the lsd in the gsr tranny? il will have traction problems soon
Old Jul 9, 2009 | 01:44 PM
ekb18c2's Avatar
New User
Stick with the GSR trannie..
Old Jul 9, 2009 | 02:05 PM
SilverEk3dr's Avatar
im running b16 1-3 & gsr 4&5th just for the mph.. working pretty good, and doing 129 in the 1/4.. Just gotta be fast with the shifting. The gears come up quick.
Old Jul 10, 2009 | 04:43 AM
I'm not Rick!
k thanx
Old Jul 10, 2009 | 06:19 AM
racebucket_eg's Avatar
Op the final drive is the same in both transmissions.
Old Jul 10, 2009 | 08:39 AM
dc2luver's Avatar
gsr trans all day
Old Jul 10, 2009 | 08:45 AM
EARLdaSQUIRREL's Avatar
official honda whore
either will work fine, the b16 will have less traction but will accelarate faster
i personally like a gsr for an all around daily driver/track car and the lsd is a must
Old Jul 10, 2009 | 01:32 PM
boostISbest's Avatar
go wit gsr
Old Jul 10, 2009 | 04:25 PM
Hybrid96EK's Avatar
How can you have less traction but accelerate faster?
Old Jul 10, 2009 | 05:36 PM
when you have good slicks/tires you will accelerate faster with b16 than you would with a gsr trans
Old Jul 10, 2009 | 05:40 PM
Hybrid96EK's Avatar
Then you wouldn't have less traction, now would you?
Old Jul 10, 2009 | 06:11 PM
gt35rdanny's Avatar
my lsd b16 tranny is just fine in my boosted car...just sucks on the freeway
Old Jul 10, 2009 | 07:02 PM
96 GSR-T's Avatar
B16 hands down rips on a boosted car, cant go wrong with either.
Old Jul 10, 2009 | 08:00 PM
VtecCarHauler's Avatar
low hp (250-400) B16 gear box
mid-high hp(400+) GSR gear box
Old Jul 10, 2009 | 08:42 PM
are you trying to **** me off?? on street tires the b16 will be slower due to spinning through the gears with anythign over 300whp
on slicks/radials the b16 will be faster than a gsr with the same wheels/tires
what rpm you take the car to, the size of your tires as well as a couple other factors all come into play
Old Jul 10, 2009 | 09:09 PM
Hybrid96EK's Avatar
No. I was simply pointing out that one must take into consideration that simply because something is geared shorter doesn't mean its going to make your car faster. More power to the ground = more traction issues. Plain and simple. Your statement about making your car faster, but increasing wheel spin just didn't make sense. I was just trying to clear it up. Relax.
Old Jul 11, 2009 | 04:42 AM
96 GSR-T's Avatar
In my experiences, wheelspin is going to happen on a 350+hp setup with either tranny. I think you shouldnt gear your car down due to wheelspin, but instead make adjustments and/or add parts to aid in traction so that you can benefit from shorter gearing. The shorter gearing will get you into boost faster, will have less RPM drop in shifts and make the car easier to accelerate around town in traffic. I would like to try a GSR trans in my car again but I know I would be pulling it back out for a B16.
Old Jul 11, 2009 | 05:22 AM
wrd. Just put a ls or gsr 5th in there to make it nice for cruizing
Old Jul 11, 2009 | 07:04 AM
Blown90hatcH's Avatar
10.10 with ITR tranny in my car. Don't bandaid the car by putting in a logger geared tranny. Get the power to the ground. If you are out of rpm or tire, then get the longer geared tranny.
For 90% of the people on here that wont bother doing that, keep the gsr tranny.
Old Jul 11, 2009 | 07:24 AM
96 GSR-T's Avatar
I got a GSR 5th in mine
Old Jul 11, 2009 | 07:45 AM
DA TeG 90's Avatar
I would say stay with the gsr tranny since you have it. If it blows, just use the b16. I will be using the b17 gsr tranny in my boosted set up, so either one will work! Short gears FTW
Old Aug 6, 2009 | 08:48 AM
HYREV2NR's Avatar
When I finish building my ITR I hope to keep the factory trans. Looking to make 400 WHP at max. I'll say with 260 at the wheels SC'd 1st and 2nd gear was useless, 3rd and 4th had decent traction. I'm sure with the turbo it will be the other way around.
LBP
Transmission & Drivetrain
Apr 21, 2013 08:29 PM
SikofFalln
Jun 1, 2008 12:42 AM
lazyxmofo
May 4, 2008 01:09 AM
SIReg9
Sep 24, 2002 05:33 PM
