vibration @ 1500rpm
Old Jul 9, 2009 | 12:03 PM
tipe R's Avatar
Default vibration @ 1500rpm
just wondering if anybody has had a vibration @ around 1500rpm. My car does it under load and while sitting. It most noticable on cold startup due to the fact that the high idle is right in that rpm range
Old Jul 9, 2009 | 02:16 PM
98ITR747's Avatar
Default Re: vibration @ 1500rpm
Can you describe the vibration a little better maybe? All R's tend to vibrate at idle because of the high compression.
Old Jul 9, 2009 | 04:39 PM
MiraiZ's Avatar
do you have a lightened flywheel?
Old Jul 10, 2009 | 05:14 AM
tipe R's Avatar
not that i know of but the previous owner said he put an exedy stage 1 in so it's possible. the vibration happens at about 1500rpm weather the engine is loaded or not, and only last for about 200rpm. I guess it could be a balance issue with the flywheel
donaldmejr
Jul 16, 2006 07:31 PM
darockstar
Mar 10, 2006 05:00 PM
TeknoJunki
14
Aug 10, 2004 10:05 AM
petrv
Sep 25, 2003 06:11 AM
Spade
Jan 8, 2003 01:51 AM
