FS/FT: 95 ej2 coupe. Heavily Modded/Swapped. LOOK@ Great DEAL
car is gone!!!!!!!!!!!!!!
TRADED
DELETE POST
well here it goes:
Open to trades and cash offers ( i can add cash on top )
trades:
94-01 dc2
92-95 hatch
99-00 si
for pics n more info call/text 443 220 7142 - Cody
selling my:
1995 Honda civic dx coupe ej2
the car is the original black
NO RUST!
around 140k miles on body
the ex cluster reads about the same.
location- maryland
( somewhere where you dont want to come looking to steal **** )
Exterior:
-JDM black housing headlights
-30k blue hids
-Smoked vision amber corners
-Brand new front bumper
-Brand new rear bumper
-(both bumpers unpainted but are factory black)
-Golden Eagle 1 piece silver diffuser
-V.I.S carbon fiber trunk
-Smoked Tail lights
-Rear eg mud flaps
-ek sideskirts
-stickers on front windshield and rear window and mirrors
-10% window tint and windshield strip
What i have thats not installed that can come with for right price$-
-jdm fender lights
-brand new oem honda fenders primered ready to install and already cut for fender lights
-jdm yellow foglights
-front lip
Interior:
-full black gsr leather interior 9/10 condition. front and back
-full black and grey stock interior 10/10 condition
-ex cluster
-pioneer h/u
-infinity speakers
-jdm coin pocket
-jdm center console
-knock off itr ****
-eg floor mats
Suspension:
-skunk 2 full coilovers. pro s series
-omni power rear lca polished
-asr rear subframe brace silver
-front and rear blox camber kits
-95 gsr rear disc conversion
-all 4 steel braided brake lines
-powerslot front and rear rotors
-all new pads front and rear
-arp extended wheel studs in front
(all brake work was just done 5k miles ago)
Rim and tire-
-rota slipstreams black 4x100 40 offset 15x7
-nitto neo gens 205 50 15 75% life
rims are mint!
-honda center caps
Extras (already on/done to vehicle)-
-wire tuck headlight harnesses are in fender wells, exterior fuse box under hood is relocated to under dash. some other things are eliminated/tucked
-steel braided clutch, fuel and fuel return lines
-innovative motor mounts polished with grey bushings i think 750 hp rating
-walboro 255 fuel pump
-gsr linkage gsr dual bend shifter w/ energy suspension bushings
Extras not on vehicle yet but can come with for the right price $ -
- Jdm gsr head. practically complete only thing is no intake manifold. i've had it sitting around thinking about doing the lsvtec swap just never got time to. the head is fresh has low miles. everything is there dizzy,solenoid, v.c, cams cam gears. i also have the lsvtec kit and brand new arp headstuds. only thing need is a fresh ls headgasket and the head tapped for lsvtec.
-traction bar
-full NOS wet kit. has everything all lines, brand new nozzle, 2 bottles, bottle brackets, electric bottle warmer w/switch, and a bunch of jets. ready to go and ready to use. the solenoids are the big soleniods. the supershots!
-s300 in p28 ecu already installed
Engine/Swap:
b18b1 ls swap
- came out of a wrecked 95 acura ls special edition with almost 90k on it.
- motor just had timing belt, waterpump, oil pump and head gasket. full complete service by honda tech. the motor runs excellent! also has a brand new distributor on it along with new valve cover gasket new tb gasket new exhaust manifold gasket.
- motor is bone stock it has a b20 valve cover on it and it has a bdl cam seal. also has a gsr tb.
- jdm gsr trans w/lsd 60 k tops. trans is butter. fresh axle seals and trans fluid.
- act 6 puck unsprung clutch heavy duty pp. fresh resurfaced flywheel.
- aftermarket megan racing header
- 2.5 in straight pipe to rsr muffler
- aem silver fuel rail and aem fpr
- nology hot wires
- intake
- blox magnetic drain plug
----car runs great never had any problems. no knocking or an wierd noises. car starts right away and runs all day long. oil changed every 3k. trans fluid changed every 10k. ask any of my vouches motor is clean and runs great. with the lsd and the short trans the car is quick. car has went 14s at the track the way it sits with the bone stock LS.
the bad:
-car just has body issues
---it has the normal little honda dents here n there on the car. the little ones that no one knows where they come from acouple on each side here n there. door, quarter panel, roof, fender ( thats why i have new ones )
---and right near the outside tailight in the rear passenger side. is a dent from the car being bumped into it cracked the tailight (replaced) and push in a lil dent. barely noticeable
---car has acouple scratches here n there and the paint. the BLACK is such a hard color to keep fresh and vibrant. when i got the car the paint wasnt taken care off. no peeling or anything just fading. i got different black doors for the car and a hood and fender. i just was coming across matching black exterior parts. the roof im on the process of redoing. and as far as the body it just needs a good waxing/buffing. or take make this car immaculant just give it a paint job.
{ overall the car just needs some exterior help and it would have the whole 9 yards. the interior is immaculant. the car rides amzing with the suspension stuff. the motors strong. just needs some paint lovin... }
PICTURES:
just random ones i put up for any veiwers. i have alot more.
-taken at the carwash. car has different wheels on it then and acouple things have changed:
-taken monday 7/6/09 fresh oil change, trans fluid change and acouple others. also i took the lip off to get on the lift.
-h.i.d s
- taken awhile ago. stuff thats changed- stickers on back window taken off, wheels
- taken off my cell phone at the car wash.
- another cell phone picture. again different wheels then. i had bronze slipstreams as well as the black ones
- pretty recent. tag location has changed and acouple other things.
as you can see theres acouple dents in hood and on pass side fender(but thats why i have brand new ones)
-pretty blacked out
- taken recently- the intake is off an integra so fitment its wierd i need to make a bracket to hold it up. also wires behind headlights are h.i.d wiring need to be re tucked one of the bulbs blew so i needed to change it.
- shows how clean the motor is:
- a older picture. stuff thats changed- wheels, mounts, intake, sparkplug wires, tag location.
-right after the brakework was done. also the rims are dirty but they clean up real nice.
just a thought?-
starting at 4200$ to 5200$ or BEST OFFER. tell me the way you want the car and with what parts and make an offer.
-parts can be taken off to lower price
-theres also alot of parts that can be added
what the car has into it briefly
-just interior alone for seats and other accesories was almost 700$
-the suspension has well over 1000$ into it
-the brakes have over 500$ into them
-the trunk and other exterior accesories are almost 800$ alone
-the trans is worth almost 1000$ and yes ive had offers close to that to buy it.
plus the motor, all the extras that can be thrown in and so much more the car is defintely well worth it and whoever gets it will be happy.
TRADED
DELETE POST
well here it goes:
trades:
94-01 dc2
92-95 hatch
99-00 si
selling my:
NO RUST!
location- maryland
Exterior:
-30k blue hids
-Smoked Tail lights
-Rear eg mud flaps
-ek sideskirts
-jdm fender lights
-front lip
Interior:
-ex cluster
-pioneer h/u
-infinity speakers
-jdm coin pocket
-jdm center console
-knock off itr ****
-eg floor mats
Suspension:
Rim and tire-
rims are mint!
-honda center caps
-traction bar
Engine/Swap:
b18b1 ls swap
- nology hot wires
- intake
the bad:
PICTURES:
-h.i.d s
-pretty blacked out
just a thought?-
94eg5squadMD
Mid-Atlantic (Sales)
16
Jul 20, 2009 06:40 PM
94eg5squadMD
Mar 27, 2008 10:21 AM
