Wierd 95 civic d15b7 idle
Old Jul 9, 2009 | 09:34 AM
Unseen Racer's Avatar
Default Wierd 95 civic d15b7 idle
so my co-worker's STOCK 95 civic Dx has a wierd idling problem.
the car osolates up and down kinda fast.
i do not know by how many RPM since it does not have a RPM gauge.
at first i thought it was the IACV, but the car only does this when it is warmed up and only when its in park on in neutral.
any1 know what the problem may be?
Old Jul 9, 2009 | 10:00 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Wierd 95 civic d15b7 idle
speed sensor? (vss)
Old Jul 9, 2009 | 11:14 AM
Former User's Avatar
Clean the FITV (and IACV) on the throttle body and also bleed the cooling system.
Old Jul 9, 2009 | 01:19 PM
j0keefe21's Avatar
all the above and possibly a vaccume leak
Old Jul 9, 2009 | 02:45 PM
where is the FITV?
i know that the IACV is located on the back of the intake mani.
also when re unplugs the Throttle body position sensor, it stops but it idles pretty high.
i would say 1,500-2,000
Old Jul 9, 2009 | 03:18 PM
j0keefe21's Avatar
my car did the same thing but it was a vaccume leak. fitv is under the throttle plate.
Old Jul 9, 2009 | 11:21 PM
how can i find a vacuum leak?
cuz i dont want to remove the FITV or IACV just to find out that that was not the problem.
have to try the easy stuff first
Old Jul 9, 2009 | 11:29 PM
sp00ledbseries's Avatar
Either of you smoke? make sure the fan is off and put a cig around the vacuum lines. Check the vss though and the coolant
Old Jul 9, 2009 | 11:32 PM
lol. nope. none of us smoke.
how will the VSS affect the idle though?
Old Jul 9, 2009 | 11:41 PM
IDK how the vss affects it but it does. Mine is bad on my hatch and it makes it idle surge. Mine is a auto though
Old Jul 10, 2009 | 10:36 AM
j0keefe21's Avatar
spray carb cleaner around your vaccume lines. if you car starts to choke out you found your leak
Old Jul 10, 2009 | 10:43 AM
Pothole987's Avatar
Check your antifreeze level. theres some sort of strip somewhere in side the engine and when the coolant gets low it revs funny.
Also have you tried resetting the ECU?
Old Jul 12, 2009 | 03:22 PM
his is an automatic as well.
still dumbfounded on how the vss could cause this
ill try this after work when i have carb cleaner
to reset the ECU, you unplug the negative battery cable for 10 seconds right?
Old Jul 12, 2009 | 03:41 PM
[quote=Unseen Racer;39190978]where is the FITV?
Click here.
Miranda.barber2
Engine Management and Tuning
May 9, 2013 07:12 PM
richi86
Mar 29, 2011 04:31 PM
elli
Jun 1, 2010 01:22 PM
Nyconn18
Mar 12, 2004 07:31 AM
V-Thang
Acura TL, RL & ZDX
Feb 24, 2004 02:10 PM
