A/C in hatch
been covered hella. you need all the piping the compressor the complete ac wiring harness (it plugs in under the dash above the ECU) the condensor the fan the evaporator the little can thingy that sits next to the washer bottle (buy a new one) the ac belt tensioner and i think that's about it. of all that you need to buy new o rings a new reciever, vacuume bleed the lines and retro fit to r134a. talk to a local a/c shop about how much oil you need to use, and weather you need to use pag or ester oil.
ok here is the problem i am having. i took an evaporator off a sedan and it seems to be to short in width for my hatch. about half an inch on each side short after bolted up. any one know why?
redman223
15
Jan 5, 2004 11:48 AM
