Full Coilover Suspension Systems for S2000/92-95 CIVIC/ 94-01 INTEGRA 499$
EMUSA Coil-Over Dampers is the perfect enhancement to your track or street car. Featuring Non-Adjustable damper force, full-height adjustment. ONLY $499.99/SET
The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can easily raise your car to oem height or lower your car for track performance.
The quality and durability of the EMUSA Racing Damper kits are made of High Grade aluminum and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection.
Features:
- Spring Rates: 8kg Front and 6kg Rear
- Non Adjustable Damper/ Adjustable damper
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
Features:
- Aluminum Brackets
GSR-T-
Apr 30, 2003 01:25 PM
