Skunk2 stage3 tuner cam degree specs
Old Jul 9, 2009 | 06:04 AM
Teamdiesel's Avatar
Default Skunk2 stage3 tuner cam degree specs
Has anyone ever degreed in these cams before? I am curious to know what was your setup and where the cams gears ended up after been degreed. Before most of you start to flake about "every setup is different", I am just curious to know.
Old Jul 9, 2009 | 08:05 AM
Teamdiesel's Avatar
Default Re: Skunk2 stage3 tuner cam degree specs
someone has to have degreed these cams before.
Old Jul 9, 2009 | 06:33 PM
Teamdiesel's Avatar
65 views and nothing????
Old Jul 10, 2009 | 12:43 AM
pr0honda's Avatar
degree them and see what it looks like it with your engine..
Old Jul 10, 2009 | 02:47 AM
anothersickhatch's Avatar
call skunk2 and ask them what they recommend, then have it tuned.
Old Jul 10, 2009 | 09:08 AM
NAH2B's Avatar
im sure someone has done it and gotten +3 and -1 but what does it matter?
Old Jul 10, 2009 | 09:40 AM
Flint707's Avatar
what's your email address, and I will get you a cam card for those cams.
Old Jul 10, 2009 | 07:05 PM
Teamdiesel's Avatar
obviously I would if i had access or owned a degree wheel. Just like skunk provides a quick setting for the pro cams, that is all i am asking
Old Oct 14, 2011 | 09:03 PM
ivan93egreppin210's Avatar
2 year bump. i need these specs as well. i just came across these cams and wiseco k594m85 85mm 13.1-14.2. at a handsome price. i will be running only e85 with 550cc or better. also what advice do you give about my proposed setup? head porting is not an option right now and i need to find the most reliable yet cost effective valve trane to run. also i have s200. can i tune with this. thanks.
Old Oct 14, 2011 | 09:22 PM
tempsohc's Avatar
When degreed in on my gsr cam dwelled ar centerline. At perfect center I got +2i +1 exhaust. Camgears were not at perfect 0 when started due to milling and decking. Your settings will vary.
Old Oct 14, 2011 | 09:43 PM
thanks tempsohc. the cams seem like a perfect fit to my pistons. i can wait to get the block back from the machine shop so i can put it together.
Old Oct 16, 2011 | 11:16 AM
where you at teamdiesel? did you ever find what you were looking for. i will call s2 in the morning and clear this up. thanks.
Old Oct 16, 2011 | 12:41 PM
00Red_SiR's Avatar
All Motor Mentor
A quick stop at Skunks website answers most questions people have:
http://www.skunk2.com/installation/305-05-0150.pdf
Old Oct 16, 2011 | 09:05 PM
thank you kindly sir. dont know why i didnt look there first.
Old Mar 11, 2017 | 05:38 AM
4Driver's Avatar
After six years later, I have the same question, Someone managed to get the quick setup for Tuner 3?
Old Sep 3, 2017 | 08:50 AM
donperry's Avatar
Thought: VTEC engagement by compressed air isn't necessary for dialing in, only for p2p and v2v clearance, right? Unless these specs are for the high lift lobes?
Old Sep 3, 2017 | 08:34 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The people asking this question here in this thread really don't understand what "degreeing" a pair of camshafts means. A "quick cam setting" or using someone elses settings is of no use... you are basically HOPING that these settings are going to work for you. If you are good with a GUESS... then go with it. Your chances of that being right are just as good as running the cams straight up at 0,0. The whole point of degreeing a pair of cams is to get the crank to cam event perfect mechanically. This orientation is affected by block deck height, head gasket thickness, crankshaft line bore/hone, cylinder head cut, and even timing belt tension just to name a few variables. So if you want it right... do it right. Degree kits can be purchased online... or find a shop who can do it for you. Stop GUESSING.
shawty22
Sep 2, 2016 03:36 PM
