Broken eg6 rear subframe
sup every 1 on hai i come to you for some help...my friend has a EH3 shell when he bought it he got it for $150 cuz the rear subframe is broke...i picked up a spot weld cutter for it but my question is will a 92-95 civic sedan rear subframe fit it? also is there a chance the da9 or dc2 subframe might work as a back up incase my friend and i can not find a 92-95 civic hatch or coupe thanks every for looking i appriciate the help
pictures?
All civic 92-95, del sol 93-97 and integra 94-01 shares the same style rear subframe. Difference are come come with 10mm nut for swaybar bracket and integra type r have the reinforcement bar thing.
Seen it done. You can un spot weld it and put a new one in. There is a tread on H-T guys swapping in the ITR rear sub frame as it is thicker and has the provsions for the D brackets for the ITR rear sway bar.
That's why I was double checking. Spot Welds are meant specificly not to be welded onto structural parts of a vehicle--like the frame for example. It's extemely dangerous
Kilpuri
Feb 24, 2009 11:42 AM
Mike K
11
Feb 23, 2005 07:32 AM
