What fuel pump setup for over 500 WHP
Old Jul 8, 2009 | 07:38 PM
rmcdaniels's Avatar
Default What fuel pump setup for over 500 WHP
I'm currently running a Walbro 255, and it's been fine for a little over 400, but I've heard that I'll need something bigger for 500. What's a good setup for 500+ ?
jdm inc's Avatar
Default Re: What fuel pump setup for over 500 WHP
add a inline bosch 044 pump.
Old Jul 8, 2009 | 07:41 PM
rmcdaniels's Avatar
Leave the Walbro in there and add the Bosch to it?
SilverEk3dr's Avatar
Bosch under the hood after the filter
should be good for 700ish
Old Jul 8, 2009 | 07:47 PM
jdm inc's Avatar
^^ yup.. Heres a pic of the setup from another thread.
Old Jul 8, 2009 | 10:04 PM
tony1's Avatar
How much power exactly? 505 or 595? For the most part, 550whp and below you shouldn't have any issues at all with only the Walbro pump.
Old Jul 8, 2009 | 10:54 PM
rmcdaniels's Avatar
Probably not much over 500. The blower that I'm using has made 489 in the past, but that was on a Ford 3.8 V6 motor.
Old Jul 9, 2009 | 09:06 PM
jdm inc's Avatar
That walbro should support 500.
Old Jul 9, 2009 | 09:34 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Do Your calculations people it is common sense…
Stock fuel system with 255 LPH pump is typically good for up to about 600 HP. Plus it all depends on what size injectors you run and other factors....
Since mostly there is not any good info on here just use these formula's I took the time to post below...
INJECTOR SIZE CALCULATION
Injector Size in lbs/hr per Injector = Expected HP X BSFC / Number of Injectors
For BSFC RICH = .60 Race Gas/Mid Range = .50 LEAN = .45
Injector sice in cc/min = [(Injector size in lbs/hr X 454) / 60] / .75
FUEL PUMP SIZE CALCULATION
Total Fuel Flow = Injector Fuel Flow in lb/hr X Number of Injectors
Fuel Flow in Gallons Per Hour = Total Fuel Flow in lb/hr / 6.25
To convert to Liters Per Hour = Fuel Flow in Gallons Per Hour X 3.8 = Fuel Flow in Liters Per Hour
If you can't understand that then you are beyond help, and go back to school for Math, Please...
Old Jul 9, 2009 | 10:32 PM
jdm inc's Avatar
^^ Good info.
slowboy90
Feb 15, 2011 01:05 PM
dturbo
Feb 27, 2005 10:32 PM
EARLdaSQUIRREL
Jul 25, 2004 03:58 AM
M.K.C.
Dec 15, 2003 08:01 PM
SpecFIB18
Jul 9, 2001 09:04 AM
