S2k cluster FS. Lowball me!
Old Jul 8, 2009 | 09:25 AM
cvcrcr99's Avatar
Default S2k cluster FS. Lowball me!
SOLD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!
Hey H-T. I got this s2k cluster off a friend of mine. He had it in his 06 RSX type S. It originally came from an 01 (ap1) S2000. I had plans of putting this into my Civic, but ended up choosing a SI cluster instead for money reasons. There is a problem though, right above the "SEL", there is a minor crack in the LCD screen. It doesn't affect the performance, but dI got this s2k cluster off a friend of mine. He had it in his 06 RSX type S. It originally came from an 01 (ap1) S2000. I had plans of putting this into my Civic, but ended up choosing a SI cluster instead for money reasons. There is a problem though, right above the "SEL", there is a minor crack in the LCD screen. It doesn't affect the performance, but doesn't look too pretty. Check the pics. Make an offer. I am not trying to make money off of this, just trying to get rid of it.
Here's a pic of the damage:
(don't mind the dust, just needs to be wiped off)
As I stated above, everything should work just fine, just the part of the RPM band that is affected may be blurred when/if you rev up that high. I do not have the plugs for the cluster, but has wiring coming out the back from when it was used on the RSX type S.
In order for this to work in your car, you will need:
- Your car's cluster wiring pinout, s2k cluster pinout (I can provide that if need be)
- Speedo-healer (unless being installed in a 05-06 RSX type S)
- EGT module from modifry.com (unless you don't care if the engine temp thingy doesn't work)
MAKE AN OFFER. Trades for parts for a 99 Civic welcomed! Nothing within reason will be denied! I just want this out of my dining room.oesn't look too pretty. Check the pics. Make an offer. I am not trying to make money off of this, just trying to get rid of it.
MAKE AN OFFER. Trades for parts for a 99 (6th Gen) Civic welcomed! Nothing within reason will be denied! I just want this out of my dining room.
Old Jul 8, 2009 | 12:56 PM
92egvx's Avatar
Default Re: S2k cluster FS. Lowball me!
bump...i want a s2k cluster but i want it to look nasty clean...glws
Old Jul 8, 2009 | 02:32 PM
cvcrcr99's Avatar
Thanks for the bump!
You could probably take the cluster apart (just a couple plastic clips) and spray the non-black part (where the crack is) with some VHT night shade from the inside to make it look clean. But I bet it would still be a little blurry (since the LCD is cracked) if you revved to around 8k. I was planning on painting it, but I decided not to and bought myself a SI cluster.
Old Jul 9, 2009 | 11:30 AM
cvcrcr99's Avatar
Bump for pending sale!
Old Jul 12, 2009 | 07:38 AM
cvcrcr99's Avatar
Bump for still being available!
Old Jul 12, 2009 | 08:32 PM
SniperX's Avatar
define not trying to make money on, meaning what is the lowest you'll take?
you can pm me if you want.
Old Jul 12, 2009 | 09:16 PM
cvcrcr99's Avatar
You have a PM SniperX.
Old Jul 13, 2009 | 08:37 PM
cvcrcr99's Avatar
ttt
Old Jul 14, 2009 | 08:31 AM
cvcrcr99's Avatar
Bump for a crack in my windshield that needs to be replaced!
SLUGFEST
Jun 2, 2013 07:32 PM
ReDrAnGeR
Oct 8, 2010 08:57 AM
cvcrcr99
Jul 14, 2009 08:31 AM
hired gun
May 2, 2003 10:15 PM
