99 ek wit b16 idle problems
Old Jul 8, 2009 | 08:53 AM
whtciv99's Avatar
New User
Default 99 ek wit b16 idle problems
i got a 99 civic ex with a b16a motor swap in it. i started it for the first time yesterday n it ran fine n idled good. then went to take it out for a test drive n when i pressed on the throttle it would bog real bad n shut down. i then got it back in my garage n tried to start it n it would start but wouldnt hold an idle at all. it smelt like rotten eggs so i took out the cat n replaced it wit a test pipe but i dont know what else it could be so any help would be greatly appriciated.
Old Jul 8, 2009 | 09:08 AM
goldfinger93030's Avatar
Default Re: 99 ek wit b16 idle problems
did you do the idle air control valve correction on the harness?
Old Jul 9, 2009 | 01:06 PM
whtciv99's Avatar
New User
ya its all hooked up correct
Old Jul 9, 2009 | 01:14 PM
Former User's Avatar
Does the CEL work and does it remain ON?
Are you sure that the rotten egg smell was from the cat rather than the battery? Caution: A battery that smells like rotten eggs is at risk of exploding. This is typically caused by a bad alternator that is over-charging the battery.
Old Jul 9, 2009 | 04:12 PM
whtciv99's Avatar
New User
what exactly is a CEL.....n the battery n the alty are both new
Old Jul 9, 2009 | 05:32 PM
royalrebel's Avatar
CEL = check engine light homie
Old Jul 9, 2009 | 05:34 PM
TheEvilBain_TDB's Avatar
Could it have jumped Time at all? Or is the ICM toast (little green box inside Dist... That tells the coal when to fire)
Old Jul 9, 2009 | 08:05 PM
Click here.
jrockb123
May 25, 2007 08:35 AM
rob_onfire
Apr 21, 2006 10:00 AM
tC_Dragon
Jun 23, 2004 04:26 AM
Rob!
Jun 21, 2003 03:25 PM
