little accident
I have a rare black 95 civic si hatch I got into a lil accident and need some feedback on fixing it. First off my core support is bent downword cause I hit a curb and my frame on the drivers side s bent down with it (not bad) from the motor mount forword. Do I get a new support an it get it welded on and my part of my frame pulled? I have a place that will weld on a core support and pull my frame for 500$ is this a good deal? And should I be neer perfect when done?
The frame should be perfect after it is pulled. Most frame racks are able to produce before and after measurements. As for pulling and putting in a support - that is great time. By my calculations you would be looking around 800.00 just for the support. Frame set up and pull would be at the least 100.00 additional. Just make sure you get the specs that way everything fit up when you put it back together.
Chil709
Sep 26, 2006 09:01 PM
EnjoyTheRideDC2
Nov 16, 2004 12:29 PM
