Northwest Alaska, Idaho, Montana, Oregon, Washington, Wyoming
little accident
Old Jul 8, 2009 | 01:09 AM
skibloosi's Avatar
Default little accident
I have a rare black 95 civic si hatch I got into a lil accident and need some feedback on fixing it. First off my core support is bent downword cause I hit a curb and my frame on the drivers side s bent down with it (not bad) from the motor mount forword. Do I get a new support an it get it welded on and my part of my frame pulled? I have a place that will weld on a core support and pull my frame for 500$ is this a good deal? And should I be neer perfect when done?
Old Jul 8, 2009 | 01:28 AM
Ruben19's Avatar
Default Re: little accident
i think that's a good deal..
dont forget to get an alignment after.
i dont think this is the right place for this thread..
Old Jul 8, 2009 | 06:21 AM
95b16hatch's Avatar
The frame should be perfect after it is pulled. Most frame racks are able to produce before and after measurements. As for pulling and putting in a support - that is great time. By my calculations you would be looking around 800.00 just for the support. Frame set up and pull would be at the least 100.00 additional. Just make sure you get the specs that way everything fit up when you put it back together.
Old Jul 8, 2009 | 11:37 AM
DC206R's Avatar
imo, if its not taht bad, i think you should, 95 Si's aren't everywhere.
Old Jul 8, 2009 | 03:40 PM
Ruben19's Avatar
95 si aren't rare
spun95
Welding / Fabrication
13
Oct 11, 2011 09:53 PM
rexfan
12
Feb 18, 2010 02:54 AM
Chil709
Sep 26, 2006 09:01 PM
EnjoyTheRideDC2
Nov 16, 2004 12:29 PM
