Where to buy an OEM ballast for a JDM ITR
Old Jul 7, 2009 | 01:47 PM
soulassassin13's Avatar
Default Where to buy an OEM ballast for a JDM ITR
Just like the title says I am looking for a shop that sells OEM ballasts for a JDM ITR. I don't need the cover, just the ballast and no ICB motorsports does not have them or cannot order them.
Old Jul 7, 2009 | 03:08 PM
Civic92Turbo's Avatar
Default Re: Where to buy an OEM ballast for a JDM ITR
have you tried hmotorsonline.com? thats where i gotten mine
Old Jul 8, 2009 | 07:50 AM
imsickofrice's Avatar
do you need one or two?
Old Jul 8, 2009 | 03:21 PM
One, but the seller needs to sell them as a pair I will do that too.
Old Jul 8, 2009 | 03:59 PM
i have a whole jdm itr headlight if you need.,.. driver side.. lmk
*check sig for pictures
Old Jul 9, 2009 | 02:32 AM
Rishiras's Avatar
email this person he can get one for you > James Chong > info@jdmsupply.com
Old Jul 9, 2009 | 10:37 PM
spoolinfool's Avatar
Check your pm
Old Jul 15, 2009 | 10:04 AM
dont need the itr headlight?
Old Mar 23, 2010 | 08:57 AM
99exd16y8's Avatar
bump for a better answer as i have now run into the same problem with my caR and can't seem to find a oem itr ballast anywhere. any help would greatly be appreciated. Thanks
Old Mar 23, 2010 | 11:35 AM
nokturnal_munkeeboy's Avatar
why don't you just upgrade to aftermarket one. it might be cheaper than oem one
Old Mar 23, 2010 | 12:36 PM
99exd16y8's Avatar
Yeah i realize that i could do that... but at the same time I want to do it the right way(being oem) becuase everything on the car is like it came from the factory, i want it all to bolt up the way the way it is intend, and i am not sure if the aftermarkets ones are exactly like the stock ones.
Old Mar 23, 2010 | 01:15 PM
i think oem spec lightning is between 3000k-4000k, with aftermarket ones you can choose what color you like. i would stay under 6-8k anything higher will be too bright. whatever you have your ballasts at you can put aftermarket there. one thing about the aftermarket ones you a have warranty. jdm might be oem but its not usdm spec
Old Mar 23, 2010 | 02:12 PM
bsmith100's Avatar
Most of the places that import engines seem like they often carry parts like this. Have you tried looking on Ebay yet? All kinds of stuff turns up there.
Old Mar 24, 2010 | 08:18 AM
Dr. DC2's Avatar
like dude said above HMO has a bunch of them in stock i know for sure!
Old Mar 24, 2010 | 12:45 PM
99exd16y8's Avatar
I called yesterday and they didn't have any, and if they did they said it would be sold with the headlight set itself.
Old Mar 24, 2010 | 07:27 PM
gourley's Avatar
I have a JDM ITR headlight, drivers side with ballast forsale, but I'm unsure of the working condition. The back plastic is cracked, but the bulb wasn't broken. I believe the plastic was cracked in transportation From Japan
Little_Nolan
Mid-Atlantic (Sales)
Dec 26, 2015 05:50 PM
k24aturbo
Nov 16, 2015 04:22 AM
JeDiMaster
Apr 29, 2011 07:15 AM
