type r motor in a eg parts..
Old Jul 6, 2009 | 07:25 PM
WillSB's Avatar
Default type r motor in a eg parts..
alright im a really really really big noob when it comes to swaps since i recently just started getting into cars and etc. and im only 17..but i was wondering if you swap a type r motor into a hatch or etc. would you need to do any modifications to the parts for the motor or will it simply just bolt on?
sorry it this is a waste of time but i thought i can get the answer here, also flame all you want im pretty sure you had this question at one point in your life.
Old Jul 6, 2009 | 07:32 PM
CivicSpoon's Avatar
Default Re: type r motor in a eg parts..
B-series driver's side mount & bracket, rear mount bracket, axles, shiftlinkage, and the correct (or chipped with the B18C5 map) ECU. Other than that, you should check out the FAQ page at the top of the 1992-2000 Civic sub-forum.
Old Jul 6, 2009 | 07:34 PM
USDMCIVICHATCH's Avatar
a type r motor bolts right into an eg/ek without any custom parts just some factory honda mounts/brackets is all it takes
Old Jul 6, 2009 | 09:35 PM
WillSB's Avatar
oops i just read my post and i guess it sounds really wrong reading, my question is that the motor is already swapped but i was wondering if i buy integra type r parts would i need to do any modifications to the parts, for example would i need to custom fit a type r cat back?
Old Jul 7, 2009 | 08:33 AM
CivicSpoon's Avatar
Specifically for the catback, you're buy it for the car, not the engine. Although the cat length, and/or flange might be different, depending on the length and flange of the header you'll be using. But it's nothing a muffler shop or a welder can't deal with.
For something like an intake, you might have to modify it to fit the Civic chassis, or just buy one specific for a B-series swap into the Civic chassis.
k-series
Southeast (Sales)
12
Nov 28, 2017 12:48 PM
maza849
Honda Civic (2001 - 2005)
Mar 23, 2007 08:39 AM
tspkenneth
Dec 16, 2004 08:58 AM
flyingduck04
Apr 8, 2004 08:39 AM
2muchPSI
Nov 13, 2002 12:24 PM
